ilogic make path
ilogic make path
sjoerd.van.der.eerden
ilogic make path
hi,
i'm writing some code to auto add balloons to my assambly.
the balloon snipped needs a entitie to attach to. entities can only be made in parts as far as i know.
the problem is that this component is present in a subassambly. and using the balloon snipped inventor cant find it.
Dim Sheet_1 = ThisDrawing.Sheets.ItemByName("Sheet:1")
Dim VIEW1 = Sheet_1.DrawingViews.ItemByName("VIEW1")
Dim ptCyl = VIEW1.SheetPoint(-0.1, 0.1)
Dim balloon1 = Sheet_1.Balloons.Add("ComponentA:1 balloon", {ptCyl }, VIEW1.GetIntent((MakePath("leidingwerk pp:1", "pijp150 d63 pp:2")), "balloon"))
 and if i use a makepath then I get an error.
any suggestions?
WCrihfield
Hi @sjoerd.van.der.eerden.  Maybe try this version, and see if it works any better for you.
Dim ptCyl As DocumentUnitsPoint2d = VIEW1.SheetPoint(-0.1, 0.1)
Dim CompArg As ComponentArgument = New ComponentArgument({"leidingwerk pp:1", "pijp150 d63 pp:2"})
Dim Intent As GeometryIntent = VIEW1.GetIntent(CompArg, "balloon")
Dim balloon1 As IManagedBalloon = Sheet_1.Balloons.Add("ComponentA:1 balloon", {ptCyl}, Intent)
...or maybe like this, as an alternative way of specifying the points collection:
Dim oPoints As IEnumerable(Of DocumentUnitsPoint2d) = {ptCyl}
Dim balloon1 As IManagedBalloon = Sheet_1.Balloons.Add("ComponentA:1 balloon", oPoints, Intent)
I am not super familiar with using the iLogic shortcuts way of adding balloons to lower level entities of an assembly in a drawing view, so this has not been tested yet.  I usually try to stick to the much longer, but better documented Inventor API route for doing things like this.
Wesley Crihfield
(Not an Autodesk Employee)
