Center and scale the view
tomislav.peran
tomislav.peran
My question is about the code I found on the following link:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-drawing-view-scale/m-p/823488...
Code is used to scale the chosen view and I have added a line to center it.
I have placed a few questions next to the code lines, so if somebody finds the time to answer them it would be great.
 ThisApplication.ActiveDocument.Sheets("Sheet:2").Activate
    Dim oDwgDoc As Document
    oDwgDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDwgDoc.Sheets.Item(2)
    Dim oView As DrawingView
    oView = oSheet.DrawingViews.Item(1)
oView.ScaleString = "1:1" -> I believe this sets the temporary scale of the view? Dim ViewWide As Double ViewWide = 35 '-> what is here 35? I know Inventor works with centimeters so I assume those are cm? Dim DrawingScale As String DrawingScale = CStr(ViewWide / oView.Width) -> is oView.Width calculated when scale is 1:1 like defined here: oView.ScaleString = "1:1"
-> why is here CStr used? I have read CStr is used to variable conversion? oView.ScaleString = DrawingScale ActiveSheet.View("VIEW4").SetCenter(148.5,210) -> what should I put to center the view? I have used mm (I use A3 sheet format) but It does not place the view in the middle of the sheet.
Tom
Cadkunde.nl
1) He sets oView.scalstring to 1:1 so what you measure oView.Width from that scale.
2) Cstr means Convert to string. If you put in a value that is a double or integer or etc, it makes sure that that input is converted to a string to prevent errors. You also have Cint or Cdbl as convert to integer or double
3) you have to reverse the X and Y position
.SetCenter(210,148.5)
Oh and i forgot your viewwide question. Its only used in the math, so you can regard it as a factor.
Daan_M
    Dim oSheet As Sheet
'-> I believe this sets the temporary scale of the view?
'->> Yes
    ViewWide = 35
'->> I think ViewWide is the width of your object in real life? not entirely sure but it is used later to create your drawing scale. So i makes sens that your real life width/drawing view width = your scale
'-> is oView.Width calculated when scale is 1:1 like defined here: oView.ScaleString = "1:1"
'->> oViewWidth is the width of your active Drawingview.
'-> why is here CStr used? I have read CStr is used to variable conversion?
'->> Cstr converts a variable to string type
'-> what should I put to center the view? I have used mm (I use A3 sheet format) but It does not place the view in the middle of the sheet.
'->> to center your drawing i would use the following: ActiveSheet.View("VIEW4").SetCenter((oSheet.Width/2),(oSheet.Height/2))
tomislav.peran
Hi Cadkunde,
Thanks for the explanation.
Is 35 value in cm?
 ViewWide = 35
 Tom
tomislav.peran
Hi Daan_M,
Great. Thanks a lot.
This is indeed much better to use than putting numbers.  I will use that.
Tom
tomislav.peran
Hi Cadkunde,
"Oh and i forgot your viewwide question. Its only used in the math, so you can regard it as a factor."
Sorry, I have missed this sentence in your answer.
Awesome. Thanks!
Tom
tomislav.peran
Small update. The line ViewWide = 35 indeed sets the view width to 35 cm.
If I set ViewWide = 42  my view will fit perfectly to an A3 sheet (420 x 297 mm).
See foto below:
Tom
