Ilogic <= question
Ilogic <= question
c.lutz
Ilogic <= question
c.lutz
 I'm relatively new to Ilogic, I have made a few parts and after an hour so of searching I cant find an answer to my question, I really don't even know how to correctly ask the question.
I'm trying to duplicate a suppliers ducting that uses the formula (A-B ≥ B-C)
Branch A is always the largest branch so I want to be able to make a form that when you select branch A's value (multi value list) it limits branch B and branch C to a value that is ≤ branch A.
I assumed it would be a simple
IF Branch A = ? Then               I don't know what to replace the ? with
Branch B is ≤ Branch A
Branch A is your primary variable in this scenario so it will always be a user input value. If you are defining the contents of your multivalue list and its members won't be subject to change then you can either code an IF statement for every Branch A value or you could use a Case Select.
Beyond that, you need to evaluate all of your parameters to create logic that will adapt to some manner of dynamic change. For instance, if Branch B is always one size smaller than Branch A, you can set the Branch A multivalue list reference its list index number and assign the value of the preceding index to Branch B.
Without knowing the finer details of your application though, it's difficult to offer much targeted help on the code side.
Please feel free to ask questions.
Curtis_Waguespack
Hi c.lutz,
I think something like this should do it. See the attached example Inventor 2015 file and play around with the ilogic form.
'reset Branch B list to default
MultiValue.SetList("Branch_B", 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16)
'reset Branch C list to default
MultiValue.SetList("Branch_C", 2,4,6,8,10,12,14,16)
Dim B_List As New ArrayList
B_List = MultiValue.List("Branch_B")
Dim C_List As New ArrayList
C_List = MultiValue.List("Branch_C")
Dim Temp_List As New ArrayList
Temp_List.Clear
For Each oItem in B_List
	If Branch_A >= oItem Then
		Temp_List.Add(oItem)
	End If
Next
MultiValue.List("Branch_B") = Temp_List
Temp_List.Clear
For Each oItem in C_List
	End If
Next
MultiValue.List("Branch_C") = Temp_List
I hope this helps.
Curtis
c.lutz
Thanks Curtis I was in the process of this when you posted.... all the way up to 40"
MultiValue.SetValueOptions(True, DefaultIndex := 0, NumericCompare := "=")
If BRANCH_A = 3 Then
MultiValue.SetList("BRANCH_C", 3)
MultiValue.SetList("BRANCH_B", 3)
ElseIf BRANCH_A = 4 Then
MultiValue.SetList("BRANCH_C", 3, 4)
MultiValue.SetList("BRANCH_B", 3, 4)
ElseIf BRANCH_A = 5 Then
MultiValue.SetList("BRANCH_C", 3, 4, 5)
MultiValue.SetList("BRANCH_B", 3, 4, 5)
ElseIf BRANCH_A = 6 Then
MultiValue.SetList("BRANCH_C", 3, 4, 5, 6)
MultiValue.SetList("BRANCH_B", 3, 4, 5, 6)
ElseIf BRANCH_A = 7 Then
MultiValue.SetList("BRANCH_C", 3, 4, 5, 6, 7)
MultiValue.SetList("BRANCH_B", 3, 4, 5, 6, 7)
ElseIf BRANCH_A = 8 Then
MultiValue.SetList("BRANCH_C", 3, 4, 5, 6, 7, 8)
MultiValue.SetList("BRANCH_B", 3, 4, 5, 6, 7, 8)
