iLogic link between MessageBox Yesbutton and InputBox
BRLMCHKD
Message 1 of 10
BRLMCHKD
Hi Inventor Forum
I'm struggling with a problem in iLogic.
Want's to make a link between the 'Yes button' in MessageBox to activate InputBox
(to enter value that controls my relevant parameter) . . . See my attachment.
But I can't find the information how to write the code
Is anyone here that could provide me some ideas? 🙂
Thanks.
BRL
kelly.young has embedded your image for clarity.
Replies (9)
Message 2 of 10
Thomas_Savage
Hello @BRLMCHKD
Have you tried the input box? I have attached a screenshot to show you which one i mean.
Place you parameter you want changing, then prompt, title, default entry.
Is this what you wanted??
Thomas.
Thomas Savage
Design Engineer
Message 3 of 10
BRLMCHKD
Hi Thomas.
Thank you very much for your answer 🙂
But I still not know how to activate the InputBox automatically based on the answer (Yes) given in the message box.
E.g. : When I answer yes, I would like that to automatically activate the InputBox to pop-up next.
I need a programming example how to write this code to give that link from MessageBox to InputBox.
Hope you understand my question/problem 🙂
KR
Bent
Message 4 of 10
Thomas_Savage
Would it be possible to attach your .ipt?
Thomas.
Thomas Savage
Design Engineer
Message 5 of 10
BRLMCHKD
Hi Thomas.
I have tried to attach my ipt, hope this will do 🙂
I'm going on weekend now.
Have a nice weekend.
Message 6 of 10
mcgyvr
Answer = MessageBox.Show("Would you like to input a value ", "Question?", MessageBoxButtons.YesNo)
        If Answer = vbYes Then
			myparam = InputBox("Enter the Value", "Value Entry", "10")
			MessageBox.Show ("Value = " & myparam, "The value I entered")
            Return
		ElseIf Answer = vbNo Then
			MessageBox.Show ("You did not want to enter a value", "No Answer")
        End If
@BRLMCHKD  Code above..
Message 7 of 10
Thomas_Savage
Good code @mcgyvr
I had this:
SyntaxEditor Code Snippet
If MessageBox.Show("Message", "Title",MessageBoxButtons.YesNo) = vbYes Then
Width = InputBox("Prompt", "Title", "Default Entry")
End If
Thomas.
Thomas Savage
Design Engineer
Message 8 of 10
mcgyvr
@Thomas_Savage wrote:
Good code @mcgyvr
I had this:
End If
Thomas.
@Thomas_Savage Yeah I just made the "long hand" version I guess which to me is always helpful to those still learning (which includes myself)..
Message 9 of 10
Thomas_Savage
Yes it is helpful @mcgyvr
I am still learning iLogic as well.
Thomas.
Thomas Savage
Design Engineer
Message 10 of 10
Kay_Rethmeier
there is not a big problem, if you need to check an inputbox with entered text (string). It's more tricky to ask for the cancel button, if your inputbox is used for integer values. Thats possible with a try...catch statement. Here is an example:
Dim myStringparam As String = InputBox("String", "Title", "Default Entry")
If myStringparam = "" Then Exit Sub
Dim myIntegerparam As Integer = InputBox("Check it out and enter nothing", "Title", 123)
'If myIntegerparam = "" Then Exit Sub ' This will cause a problem, "converting string in double..."
Try
	Dim myIntegerparam2 As Integer = InputBox("Integer", "Title", 456)
	MsgBox("You entered as string: " & myStringparam & vbCr & "You entered as integer: " & myIntegerparam2)
Catch
	MsgBox("You entered nothing, a not guilty value or a canceled the messagebox")
End Try
Bye
Kay
Cheers
Kay (Principal CAD-Consultant)
