iLogic- iProperty value according to keyword in other iProperty
mech_eng
Message 1 of 31
mech_eng
Is it possible for an iLogic rule in an assembly to do the following:
- check for a each component. for example, in the iProperty Description any keyword, for example, Bolt or Bolt.
- in case a keyword exists, special iProperty value is assigned to other iProperty (i.e., Title) for this component
- in case if there is no such keyword, check the next component ... and so on.
Replies (30)
Message 21 of 31
marcin_otręba
hi,
what inventor you use ?
I checked and it works for me only odoc must be declared, and material must be present in your library.
Dim odoc As PartDocument
For Each oOccurrence In ThisDoc.Document.ComponentDefinition.Occurrences
odoc=oOccurrence.Definition.Document
If odoc.PropertySets(3).Item("Description").Value.ToString.ToLower.Contains(my_prop_val.ToLower) Then
iProperties.Value(oOccurrence.Name, "Summary", "Title") = GoExcel.CellValue("B" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Title_En") = GoExcel.CellValue("C" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Title_Lt") = GoExcel.CellValue("D" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Title_Ru") = GoExcel.CellValue("E" & MyRow)
Dim assetLib As AssetLibrary
Dim libAsset As Asset
assetLib = ThisApplication.AssetLibraries.Item("Materialy")
Try
	odoc.ComponentDefinition.Material = odoc.Materials.Item(GoExcel.CellValue("L" & MyRow))
Catch
		Try
		libAsset = assetLib.MaterialAssets.ItemGoExcel.CellValue("L" & MyRow))
		libAsset.CopyTo(odoc, True)
Catch End Try End Try Try odoc.ActiveAppearance=odoc.AppearanceAssets.Item(GoExcel.CellValue("P" & MyRow)) Catch Try libAsset = assetLib.AppearanceAssets.Item(GoExcel.CellValue("P" & MyRow)) libAsset.CopyTo(odoc, True) odoc.ActiveAppearance=odoc.AppearanceAssets.Item(GoExcel.CellValue("P" & MyRow)) Catch End Try End Try End If Next
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 22 of 31
mech_eng
I am using Inventor Pro 2012
Message 23 of 31
marcin_otręba
Try this:
odoc.iproperties.material=GoExcel.CellValue("L" & MyRow)
odoc.iproperties.PartColor=GoExcel.CellValue("P" & MyRow)
Next
Ideas
or check my apps:
Message 24 of 31
mech_eng
Error Mesage:
System.MissingMemberException: Common member "iproperties" for type "PartDocument" not found.
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 25 of 31
marcin_otręba
sorry i do not have 2012 and i do not remember how it was , but you can try last one:
odoc=ThisApplication.Documents.Open(odoc=oOccurrence.Definition.Document.fullfilename,True)
iProperties.Material = GoExcel.CellValue("L" & MyRow)
iProperties.PartColor=GoExcel.CellValue("P" & MyRow)
odoc.save
odoc.close(True)
Next
It will open part document and change material and color in it.
Ideas
or check my apps:
Message 26 of 31
mech_eng
Error message:
(Sorry but the text on my machine in row System.NullRef... is appear in Russian and I have translated it)
System.NullReferenceException: Oblect variable or block With variable is not defined
(Не задана переменная объекта или переменная блока With).
at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ctor(Object Instance)
Message 27 of 31
mech_eng
Instead
Should be
odoc.oOccurrence.Definition.Document
And instead
Should be
odoc.ThisApplication.Documents.Open(odoc=oOccurrence.Definition.Document.fullfilename,True)
Message 28 of 31
marcin_otręba
sorry,
instead of :
should be
odoc=ThisApplication.Documents.Open(oOccurrence.Definition.Document.fullfilename,True)
could you place here your full code ?
Ideas
or check my apps:
Message 29 of 31
mech_eng
Full code:
Dim oProject As DesignProject
oProject = ThisApplication.DesignProjectManager.ActiveDesignProject
Dim oName As String
oName = oProject.Name
oName = "\" + oName + ".ipj"
Dim my_prop_val As String
Dim oProjectPath As String
oProjectPath = oProject.FullFileName
Dim oPath As String
oPath = oProjectPath.Replace (oName, "")
GoExcel.Open(oPath & "\_iLogic\iLogic_iProp.xlsx", "Fasteners")
'Open Excel file'
MyRow = InputBox("Specify the type:" & vbCrLf & _
"2 - Bolt" & vbCrLf & _
"3 - Screw" & vbCrLf & _
"4 - Nut" & vbCrLf & _
"5 - Washer", "Import Row", "2")
Select Case MyRow
	Case "2"
	my_prop_val = "Bolt"
	Case "3"
	my_prop_val = "Screw"
	Case "4"
	my_prop_val = "Nut"
	Case "5"
	my_prop_val = "Washer"
End Select
'Prompt User To Choose row To read In,
'Get the iProperty from selected Row For Each column
Dim oOccurrence As ComponentOccurrence
iProperties.Value(oOccurrence.Name, "Project", "Stock Number") = GoExcel.CellValue("F" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Shape_En") = GoExcel.CellValue("G" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Shape_Lt") = GoExcel.CellValue("H" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Shape_Ru") = GoExcel.CellValue("I" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Certificate_Norm") = GoExcel.CellValue("J" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Certificate_Type") = GoExcel.CellValue("K" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Full") = GoExcel.CellValue("L" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Dim_d") = GoExcel.CellValue("M" & MyRow)
iProperties.Value(oOccurrence.Name, "Custom", "Material_Dim_L") = GoExcel.CellValue("N" & MyRow)
odoc=ThisApplication.Documents.Open(odoc.oOccurrence.Definition.Document.fullfilename,True)
iProperties.PartColor = GoExcel.CellValue("P" & MyRow)
odoc.Save
odoc.Close(True)
Next
Then, error message:
System.NullReferenceException: The variable of object or the variable of block With is not defined (Не задана переменная объекта или переменная блока With).
Ragards
Message 30 of 31
marcin_otręba
You didin't correct line wchich i wrote.
Corrected code:
Dim oass As AssemblyDocument=ThisDoc.Document
Dim oName As String
Dim oPath As String
'Open Excel file'
Select Case MyRow
	Case "2"
	Case "3"
	Case "4"
	my_prop_val = "Nut"
	Case "5"
End Select
GoExcel.Open( "C:\Vault\_iLogic\iLogic_iProp.xlsx", "Fasteners")
For Each oOccurrence In oass.ComponentDefinition.Occurrences
If oOccurrence.Definition.Document.PropertySets(3).Item("Description").Value.ToString.ToLower.Contains(my_prop_val.ToLower) Then
'odoc=ThisApplication.Documents.Open(oOccurrence.Definition.Document.fullfilename,True)
odoc.componentdefinition.Material = ThisApplication.StylesManager.Materials.Item(GoExcel.CellValue("L" & MyRow))
odoc.ActiveRenderStyle= odoc.RenderStyles.Item(GoExcel.CellValue("P" & MyRow))
iLogicVb.UpdateWhenDone = True
Next
GoExcel.Close
Ideas
or check my apps:
Message 31 of 31
mech_eng
Thank You very much !
It works
