Part and Sheetmetal extents from assembly using ilogic
Message 1 of 16
Hi All,
I am into an ilogic to get extents of part and sheet metal from Assembly. I have ended up in a logic in which i can get the part extents from Assembly but the value of Sheet metal extents are different. For this I am running a seperate ilogic to get sheetmetal dimensions. I tried options to combine these two ilogic to run a single rule for an assembly comprising of both part and sheetmetal components.
Can anyone provide a suggestion to combine these two seperate rules together using an If else loop?
I am posting the two rules which I have been using.
For sheetmetal extents:
Sub Main()
'Determines if there is a flat pattern
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
'ensure this part has a flat pattern
Dim oSMDef As SheetMetalComponentDefinition
oSMDef = oDoc.ComponentDefinition
If oSMDef.FlatPattern Is Nothing Then
'Warns the user there is no flat pattern
'MessageBox.Show("This file has no flat pattern", "iLogic")
Else
Extents
End Sub
Sub Extents()
extents_length = SheetMetal.FlatExtentsLength
extents_width = SheetMetal.FlatExtentsWidth
LengthFrac = Round(SheetMetal.FlatExtentsLength, 0)
WidthFrac = Round(SheetMetal.FlatExtentsWidth, 0)
Dim oValue As String
Dim param As Parameter
If extents_width > extents_length Then
oValue = (WidthFrac & " x " & LengthFrac & " x " & Thickness)
iProperties.Value("Custom", "StockSize") = oValue
Else
oValue = (LengthFrac & " x " & WidthFrac & " x " & Thickness)
End Sub
In Assembly to get part extents:
Public Sub Main()
' Reading the current assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Reading current assembly component definition.
Dim oAsmDef As AssemblyComponentDefinition
oAsmDef = oAsmDoc.ComponentDefinition
' Reading Child part(leaf occurrences) of the assembly.
Dim oLeafOccs As ComponentOccurrencesEnumerator
oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
' Iterate through all part occurrences in assembly.
For Each oOcc In oLeafOccs
L = Math.Abs(oOcc.RangeBox.MaxPoint.X - oOcc.RangeBox.MinPoint.X) * 10
W = Math.Abs(oOcc.RangeBox.MaxPoint.Y - oOcc.RangeBox.MinPoint.Y) * 10
H = Math.Abs(oOcc.RangeBox.MaxPoint.Z - oOcc.RangeBox.MinPoint.Z) * 10
Dim oList As New ArrayList
oList.Add(L)
oList.Add(W)
oList.Add(H)
Call oList.Sort()
iProperties.Value(oOcc.Name, "Custom", "Length")= oList.Item(2)
iProperties.Value(oOcc.Name,"Custom", "Width") = oList.Item(1)
iProperties.Value(oOcc.Name, "Custom", "Thickness") = oList.Item(0)
Smallest = oList.Item(0)
Middle = oList.Item(1)
Largest = oList.Item(2)
iProperties.Value(oOcc.Name, "Custom", "StockSize") = Largest & " x " & Middle & " x " & Smallest & " "
Next
End Sub
Can anyone suggest a way to combine both?
Thanks in advance.
Aswin Mathai
Replies (15)
Message 2 of 16
marcin_otręba
hi,
you can check this one :
Public Sub Main()
	Dim odoc As PartDocument
	Try
		odoc=oOcc.definition.document
		Catch
		End Try
	Dim oSMCD As SheetMetalComponentDefinition
oSMCD = odoc.ComponentDefinition
' Look for Flatpattern
If Not oSMCD.HasFlatPattern Then
   oSMCD.Unfold()
   odoc.Update2(True)
   oSMCD.FlatPattern.ExitEdit
Else
Dim fp As FlatPattern = oSMCD.FlatPattern
L = fp.Length*10
W = fp.Width*10
H = oSMCD.Thickness.Value*10
oList.Add(L)
oList.Add(W)
oList.Add(H)
Call oList.Sort()
Next
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 16
Hi @marcin_otręba ,
Thanks for your valuable time and the support provided.
The code was working good for Assemblies that contain only sheet metal components. When I am using the same code for the part document, it returns no value.
Also, in case of sheet metal parts, if am mirroring one of the sheet metal part, then the value that is displayed of the mirrored components are different that the parent component. To solve this I have used the reuse option insted of mirror option.
Could you please check into the below code? This one works good for components other than sheet metal. but itsnot returning any value for sheet metal parts.
Public Sub Main()
	Dim sDocumentSubType = odoc.SubType
		sdoc = odoc.SubType
If sdoc = "{4D29B490-49B2-11D0-93C3-7E0706000000}" Then
		L = Round((Math.Abs(oOcc.RangeBox.MaxPoint.X - oOcc.RangeBox.MinPoint.X) * 10),0)
		W = Round((Math.Abs(oOcc.RangeBox.MaxPoint.Y - oOcc.RangeBox.MinPoint.Y) * 10),0)
		H = Round((Math.Abs(oOcc.RangeBox.MaxPoint.Z - oOcc.RangeBox.MinPoint.Z) * 10),0)
		oList.Add(L)
		oList.Add(W)
		oList.Add(H)
		Call oList.Sort()
	If sdoc = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Else
Next
End Sub
Can you guide in this?Thanks in advance.
Aswin Mathai
Message 4 of 16
marcin_otręba
hi,
The code was working good for Assemblies that contain only sheet metal components. When I am using the same code for the part document, it returns no value. - you wanted code for sheetmetal extens. It works for sheetmetal components.
Also, in case of sheet metal parts, if am mirroring one of the sheet metal part, then the value that is displayed of the mirrored components are different that the parent component. To solve this I have used the reuse option insted of mirror option. This  is because in part wchich have derivered component sheetmetal style if wrong , and must be equal to derivvedparts.
Could you please check into the below code? This one works good for components other than sheet metal. but itsnot returning any value for sheet metal parts. - i corrected your code.
Public Sub Main()
	Dim sdoc = odoc.SubType
		oList.Add(L)
		oList.Add(W)
		oList.Add(H)
		Call oList.Sort()
		Try
		Catch
		End Try
		If odoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count = 1 Then
			Dim sh As SheetMetalComponentDefinition=odoc.ComponentDefinition
			sh.SheetMetalStyles.Item (odoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).parent.ActiveSheetMetalStyle.name).Activate
		   oSMCD.Unfold()
		   odoc.Update2(True)
		extents_length  = fp.Length
		extents_width = fp.Width
		Thickness = oSMCD.Thickness.Value
		LengthFrac = Round(extents_length, 0)
		WidthFrac = Round(extents_width, 0)
				iProperties.Value(oOcc.Name, "Custom", "StockSize") = oValue
			Else
Next
End Sub
Message 5 of 16
Hi @marcin_otręba ,
Thanks for the solution.
Why could this error be popping up?
Aswin mathai
Message 6 of 16
marcin_otręba
i found one mistake in line :
odoc=oOcc.definition should be odoc=oOcc.definition.document, but i didint get an error running this rule at my inventor.
Public Sub Main()
		oList.Add(L)
		oList.Add(W)
		oList.Add(H)
		Call oList.Sort()
		Try
		Catch
		End Try
			sh.SheetMetalStyles.Item (odoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).Parent.ActiveSheetMetalStyle.name).Activate
		   oSMCD.Unfold()
		   odoc.Update2(True)
			Else
Next
End Sub
Message 7 of 16
Hi @marcin_otręba ,
Sorry to bother you again.
1. While running the code, it opens each file in a seperate window, and then it gets the value. Is there a way to avoid this?
2. The code returns error file if a part is not having flat pattern.
Aswin Mathai
Message 8 of 16
marcin_otręba
hi,
1. While running the code, it opens each file in a seperate window, and then it gets the value. Is there a way to avoid this? - if flat pattern is missing it must be unfolded, when you run unfold method then file is open in seperate window.
2. The code returns error file if a part is not having flat pattern. - i corrected it
Public Sub Main()
Dim oOcc As ComponentOccurrence
		odoc=oOcc.Definition.Document
		oList.Add(L)
		oList.Add(W)
		oList.Add(H)
		Call oList.Sort()
		Try
		odoc = oOcc.Definition.Document
		Catch
		End Try
			sh.SheetMetalStyles.Item (odoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).ReferencedDocumentDescriptor.ReferencedDocument.componentdefinition.ActiveSheetMetalStyle.name).Activate
 			 odoc = ThisApplication.Documents.Open(oOcc.Definition.Document.fullfilename,True)
		   oSMCD.Unfold()
		   odoc.Update2(True)
		 odoc.save
		 odoc.close
			Else
Next
End Sub
Message 9 of 16
Hi @marcin_otręba,
Thanks for the solution. It worked. Thanks for the help once again.
Aswin mathai
Message 10 of 16
marcin_otręba
Nice to hear that.Could you accept it as solution then.
Message 11 of 16
deffysalfauzi
stock size is different (in milimeter), how to fix it, please.
Screenshot 2024-06-28 142544.pngScreenshot 2024-06-28 142413.pngScreenshot 2024-06-28 142444.png
Message 12 of 16
marcin_otręba
Inventor stores valueas in cm not in mm, code corrected to be:
Public Sub Main()
		oList.Add(L)
		oList.Add(W)
		oList.Add(H)
		Call oList.Sort()
		Try
		Catch
		End Try
		   oSMCD.Unfold()
		   odoc.Update2(True)
		 odoc.save
		 odoc.close
		Thickness = oSMCD.Thickness.Value * 10
		LengthFrac = Round(extents_length, 0) *10
		WidthFrac = Round(extents_width, 0) * 10
			Else
Next
End Sub
Message 13 of 16
deffysalfauzi
Thanks. It worked. I have one more question. If the plate size is changed, can the stock size automatically update without having to click 'Run' or 'Regenerate'?
Message 14 of 16
marcin_otręba
you can put code from below into external rule ad set it to be run before document save event using itrigger:
If ThisApplication.ActiveEditDocument.subtype = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Try
		odoc=  ThisApplication.ActiveEditDocument
		Catch
		End Try
 			 odoc = ThisApplication.Documents.Open(odoc.fullfilename,True)
		   oSMCD.Unfold()
		   odoc.Update2(True)
		 odoc.save
		 odoc.close
				Try
					odoc.propertysets.item(4).item("StockSize").Value = oValue
					Catch
					odoc.PropertySets.Item(4).Add(oValue, "StockSize")
					End Try
			Else
			Try
					Catch
					End Try
Message 15 of 16
deffysalfauzi
Thank you very much. How do I add material in oValue, for example: SUS316L, 1.5 x 100 x 50 mm?
Message 16 of 16
marcin_otręba
easiest way is:
ps. i corrected previous code.
	Try
	Catch
	End Try
		  	oSMCD.Unfold()
		  	odoc.Update2(True)
			oValue = "=<Material>, " & (WidthFrac & " x " & LengthFrac & " x " & Thickness)
			Try
				odoc.PropertySets.Item(4).Item("StockSize").Value = oValue
			Catch
			End Try
		Else
			oValue = "=<Material>, " & (LengthFrac & " x " & WidthFrac & " x " & Thickness)
			Try
			Catch
			End Try
