ilogic insert drawing format
Message 1 of 9
I would like to use ilogic to place a sheet format onto an idw...  I am not simply wanting to put the right border and title block on, I have a number of sketched symbols that also make up the sheet format in the drawing resources and I would like to choose one of them
Replies (8)
Message 2 of 9
Anyone got any ideas?
Message 3 of 9
Ktomberlin
Message 4 of 9
Thanks but I dont think so.  I have a number of sheet formats setup in my template, different sizes, different sketched symbols etc, I just want to be able to create a new sheet choosing one of these sheet formats using ilogic
Message 5 of 9
waynehelley
Hi Stephen,
I have some VBA code which I use to delete the existing border and title block from an existing drawing and replace them (as well as sketch symbols) from a defined template (as well as updating the documents styles to match my local styles)
The code was initially created by someone at my parent company so some of it I don't quite understand but I managed to manipulate it to do what I needed it for.  Hope this may be as some use to you!
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Message 6 of 9
waynehelley
When it gets to the part where the file location of the template is specified, you could add a pop-up box where you then have a selection between the different templates you want to be able to choose from.
Wayne Helley
Visual Studio 2022
Message 7 of 9
thanks but it looks like a bit of overkill and setup involved.  sheetformat is a standard inventor object but I cant find out how to reference it
Message 8 of 9
would still love to do this easily...
Message 9 of 9
bump...  is this not possible
