iLogic include work axis from assembly to drawing
Message 1 of 13
Hello all,
Could anybody help me with edditing code:
Dim doc As DrawingDocument = ThisDoc.Document
For Each sheet As Sheet In doc.Sheets
    For Each view As DrawingView In Sheet.DrawingViews
        Dim camera As Camera = View.Camera
        If (camera.ViewOrientationType = ViewOrientationTypeEnum.kIsoTopRightViewOrientation) Then
            Continue For
        End If
        Dim refDoc = View.ReferencedDocumentDescriptor.ReferencedDocument
        Dim axis As WorkAxes = refDoc.ComponentDefinition.WorkAxes
        View.SetIncludeStatus(axis.Item(1), True)
        View.SetIncludeStatus(axis.Item(2), True)
        View.SetIncludeStatus(axis.Item(3), True)
    Next
Next
 I want include work axis from assembly to drawing - include controll ilogic rule.
Is possible to define for what drawing view and for what axis (by name)?
Thanks a lot.
Replies (12)
Message 2 of 13
JhoelForshav
Hi @Anonymous
Are you looking for something like this?
The rule lets you pick the view in the drawing and then answer yes/no if you want to include the axes...
Dim View As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Pick view")
Dim oAxes As WorkAxes = refDoc.ComponentDefinition.WorkAxes
For Each oAxis As WorkAxis In oAxes
	Dim oInclude As DialogResult
	oInclude = MessageBox.Show("Include " & oAxis.Name & "?", "Include Axis", _
	MessageBoxButtons.YesNo, MessageBoxIcon.Question)
	If oInclude = DialogResult.Yes Then
		View.SetIncludeStatus(oAxis, True)
	Else
		View.SetIncludeStatus(oAxis, False)
	End If
Next
Message 3 of 13
thats instring too.
But this is not what I need.
I need this:
If teplomer not suprres do:
include Work Axis5 - include / visibly.
If teplomer is suprres - Work Axis5 will be unvisibly.
(in drawing will be more views, so i need to specific for what view I want to include the axis. but by name not with click set.)
I know how to do If.... and so on, but I´m fighting with VBA.
Message 4 of 13
JhoelForshav
@Anonymous
I assume you mean if "teplomer" is invisible in the view, not suppressed?
Try this,
Dim oSheet As Sheet = ActiveSheet.Sheet
Dim oViewName As String = "VIEW1" 'Name of the view
Dim oView As DrawingView
For Each osView As DrawingView In oSheet.DrawingViews
	If osView.Name = oViewName
		oView = osView
		Exit For
	End If
Next
If oView Is Nothing
	MsgBox("No view found with name: " & oViewName)
	Exit Sub
End If
Dim refDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oDef As AssemblyComponentDefinition = refDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence = oDef.Occurrences.ItemByName("teplomer")
Dim oAxis As WorkAxis = oDef.WorkAxes.Item("Work Axis5") 'Get axis by name
If oView.GetVisibility(oOcc) = True 'See if teplomer is visible
	oView.SetIncludeStatus(oAxis, True)
Else
	oView.SetIncludeStatus(oAxis, False)
End If
Message 5 of 13
I want only:
Visibly axis if teplomer isn´t supress in assembly.
I need to dimension angle of teplomer in drawing. So if I don´t have teplomer in assy, I don´t want to include axis in drawing.
Your code show me error. I don´t know why.
Message 6 of 13
JhoelForshav
Were you running the code on a view based on a part when you got the error?
Could you attach the assembly? 🙂
Message 7 of 13
sorry my mistake. I wrote wrong view name. (first capital letter).
I little bit change your code: Visibility is controlled by linked paramter:
Dim oViewName As String = "Hlavni" 'Name of the view
		oView = osView
		Exit For
	End If
Next
If oView Is Nothing
	Exit Sub
End If
'Dim oOcc As ComponentOccurrence = oDef.Occurrences.ItemByName("teplomer")
If Parameter("ENG-000218317-P.ipt.teplomer_01") = 0.000 ul 'See if teplomer is supress
Else
End If
If teplomer is availabilite then  Parameter("ENG-000218317-P.ipt.teplomer_01") = 1 ul
If teplomer is suppress then  Parameter("ENG-000218317-P.ipt.teplomer_01") = 0 ul
I can´t linked True/ false parametr from base component..
But, one more problem :/. If axis get visibly, it´s "small", can I manage size of axis in code?
Message 8 of 13
JhoelForshav
@Anonymous
Seems like you want to move the endpoint of the centerline representing the axis.
Maybe something like this?
		oView = osView
		Exit For
	End If
Next
If oView Is Nothing
	Exit Sub
End If
Else
End If
Dim oAxisLine As Centerline = oSheet.Centerlines.Item(oSheet.Centerlines.Count)
'Should be the last centerline, otherwise try below for loop to get it...
'For Each ocLine As Centerline In oSheet.Centerlines
'	If ocLine.ModelWorkFeature Is oAxis
'		oAxisLine = ocLine
'		Exit For
'	End If
'Next
Dim oPoint As Point2d = oAxisLine.EndPoint.Copy
Dim oVector As Vector2d = oAxisLine.Geometry.Direction.AsVector.Copy
oVector.ScaleBy(10) 'Set distance to move endpoint of line.
oPoint.TranslateBy(oVector)
oAxisLine.EndPoint = oPoint
Message 9 of 13
Yes you´re right. But it´s look that end point going to out of drawing view.
I tried to change vector to (-10) etc..But nothing help. Maybe change:
To something like:
oAxisLine.StartPoint.Copy ?
Message 10 of 13
JhoelForshav
@Anonymous
try this instead 🙂
		oView = osView
		Exit For
	End If
Next
If oView Is Nothing
	Exit Sub
End If
Else
End If
'		Exit For
'	End If
'Next
Dim oPoint As Point2d = oAxisLine.StartPoint.Copy
oVector.ScaleBy(-10)
oAxisLine.StartPoint = oPoint
Message 11 of 13
@JhoelForshav thank you a lot!
Where do you learn it?
I tried to find some books, but I found just one book from Autodesk, but there are just elementary knowledge.
Message 12 of 13
JhoelForshav
@Anonymous
You're welcome. I think it's best to move the scaling of the axis to within the if-statement. So you don't do all of that if the axis isn't included...
		oView = osView
		Exit For
	End If
Next
If oView Is Nothing
	Exit Sub
End If
Else
	'		Exit For
	'	End If
	'Next
End If
I've learnt a lot from this forum or just googling stuff.
The API reference manual here is great for looking up objects and their properties, functions etc.
https://help.autodesk.com/view/INVNTOR/2020/ENU/
Message 13 of 13
TecnicoPanni
Hi JhoelForshav
I'd like to include the work axis of a part in the assembly view, not of the assembly itself.
After selecting the view, is there a way to select the part I like in the selected view?
Thank you
