iLogic Ignore Construction Lines on Sketch Extents
dsl145
dsl145
I've got the following code to determine the extents of a sketch for a swept part, but it's picking up the construction lines for the sketches as well. Is there any way to just have it take the extents of the drawn components and ignore the construction lines.
Code below:
Public Function GetSketchExtents
Dim sSketch As PlanarSketch
sSketch = ThisDoc.Document.ComponentDefinition.Features.SweepFeatures.Item(1).Profile.Parent
Dim oSketchRange As Box2d
oSketchRange = ThisApplication.TransientGeometry.CreateBox2d
Dim oEntity As SketchEntity
For Each oEntity In sSketch.SketchEntities
Call oSketchRange.Extend(oEntity.RangeBox.MinPoint)
Call oSketchRange.Extend(oEntity.RangeBox.MaxPoint)
Next
'MsgBox("(Values)" & vbCrLf & _
'"MaxPoint.X [cm]= " & oSketchRange.MaxPoint.X & vbCrLf & _
'"MinPoint.X = [cm]" & oSketchRange.MinPoint.X & vbCrLf & _
'"MaxPoint.Y = [cm]" & oSketchRange.MaxPoint.Y & vbCrLf & _
'"MinPoint.Y = [cm]" & oSketchRange.MinPoint.Y)
dblHeight = ((oSketchRange.MaxPoint.X - oSketchRange.MinPoint.X)/2.54)
dblWidth = ((oSketchRange.MaxPoint.Y - oSketchRange.MinPoint.Y)/2.54)
'"dblHeight = [in]" & dblHeight & vbCrLf & _
'"dblWidth = [in]" & dblWidth)
End Function
WCrihfield
You just need to add an extra check at the beginning of the loop for its Construction boolean property, like this.
Sub Main
	MsgBox("Hi")
End Sub
Dim sSketch As PlanarSketch = ThisDoc.Document.ComponentDefinition.Features.SweepFeatures.Item(1).Profile.Parent
Dim oSketchRange As Box2d = ThisApplication.TransientGeometry.CreateBox2d
	If oEntity.Construction = False Then
Next
End Function
Wesley Crihfield
(Not an Autodesk Employee)
AlexKorzun
Please try .Construction property of SketchEntity to find out.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
