How to set a conditional Rule to match body visibility and component visibility?
caroline_ccc
caroline_ccc
Hello. Hope you all are doing well.
I have a question and would appreciate your help.
If i want to set a rule as:
If Solid 2x3. Visible = false   Then
Component.IsActive("Top Section") = False
I know the rule won't be something as simple as this. But I think it`s explaining well.
WCrihfield
See if this works for you:
Dim oADoc As AssemblyDocument = ThisAssembly.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oMBPart As PartComponentDefinition = oADef.Occurrences.ItemByName("Rectangular Top Section for spikes").Definition
If oMBPart.SurfaceBodies.Item("Solid 2x3").Visible = False Then
Wesley Crihfield
(Not an Autodesk Employee)
caroline_ccc
Thanks for your help.
Here is the message when I run the rule.
"Conversion from string "Solid 2x3" to type 'Integer' is not valid."
WCrihfield
It must not have liked using its name as its Item().  Usually you can get away with this.
Try it this way instead.  It's a bit longer, but should be more stable.  Working with component names can be tricky, because the system automatically put a colon : and an Integer at the end of each name, by default, so multiple instances of it have different names from each other.
Dim oBody As SurfaceBody
For Each oSBody As SurfaceBody In oMBPart.SurfaceBodies
'	If oSBody.Name = "Solid 2x3" Then
	If oSBody.Name.Contains("Solid 2x3") Then
		If oSBody.Visible = False Then
			For Each oComp As ComponentOccurrence In oADef.Occurrences
				If oComp.Name.Contains("Top Section") Then
					If oComp.Suppressed = False Then
						oComp.Suppress
			Next
Next
Wesley Crihfield
caroline_ccc
Thanks again.
This is showing this error.
"Variable 'ocomp' hides a variable in an enclosing block."
But the first rule works perfectly if we change the "name" of the solid per the "position" of the solid in the list.
"Solid 2x3"  is the  6th .
''''''This works '''''
If oMBPart.SurfaceBodies.Item(6).Visible = False Then
	Component.IsActive("Fiberwall Washer2x3") = False
WCrihfield
Good to hear. That last error usually happens when you define a variable in two different levels of the code blocks, but I'm not seeing where I defined the variable "oComp" anywhere other than right where I'm using it.
I usually like to define all variables above/before a loop, then use them or set their values within the loop, but apparently I didn't follow my own rules here. 😒
Wesley Crihfield
caroline_ccc
Probably i had another "oComp" somewhere in my giant rule here I`m creating. That's why.
All sorted with a simple condition rule.
Thanks again! 😁
