iLogic: How to trigger a standalone .exe
Message 1 of 8
Hi
I've tried searching the forums for this one, but no luck.
Is it possible to have an iLogic rule trigger a standalone .exe?
Regards
Bredo Norhall
Replies (7)
Message 2 of 8
jdkriek
Yes, that's possible with the VB Shell() command.
Just paste this in your rule.
Shell("C:\TEMP\NameOf.exe")
 Don't forget that iLogic is essentially Visual Basic 😉
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 8
jletcher
What are you trying to run with the exe file? Are you just trying to open something?
Message 4 of 8
Thanks Smiley Happy
Message 5 of 8
jdkriek
You're welcome Bredo 😉
Jonathan D. Kriek
Message 6 of 8
Hi Jonathan,
My "standalone.exe" gets triggered all right, but it hides behind the Inventor 2014 window. Although the Property: 'TopMost' of the form is set to True.
Do I need to add something in the rule or in the VB.net file?
Best Regards,
Hans Rosbergen
Message 7 of 8
At last I found this syntax:  ThisDoc.Launch(“path\file.ext”)
Wich works for me. It got it from:
http://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/...
Cheers
Message 8 of 8
David-Truyens
@Anonymous Thanks! That's the only correct answer instead of fooling around with the topmost's and those kind of settings 🙂
