iLogic: How to get Item Number of ActiveSheet in Sheets Object?
j.pavlicek
Message 1 of 8
j.pavlicek
is there a smarter way how to get an Item Number of particular Sheet object in Sheets Object?
Only way what I have found yet is:
Dim oDoc As DrawingDocument
Dim oSheet As Sheet
oSheet = ActiveSheet.Sheet
oDoc = oSheet.Parent
Dim oSheet2 As Sheet
Dim iSheetIndex As Integer = 0
For Each oSheet2 In oDoc.Sheets
	iSheetIndex += 1
	If oSheet Is oSheet2 Then Exit For
Next
Logger.Info("Index = " & iSheetIndex)
I think there has to be more elegant way how to do it.
Thanks.
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Replies (7)
Message 2 of 8
JhoelForshav
Hi @j.pavlicek
Something like this maybe? 🙂
Dim oSheet As Sheet = ActiveSheet.Sheet
Dim oDoc As DrawingDocument = oSheet.Parent
'Convert to list to use IndexOf
'List index starts at 0 while indexes of oDoc.Sheets starts at 1, thats why I add +1
Dim oIndex As Integer = oDoc.Sheets.OfType(Of Sheet).ToList().IndexOf(oSheet) + 1
'Check to see that we got the correct sheet
MsgBox(oDoc.Sheets(oIndex).Name)
Message 3 of 8
NachoShaw
i have something similar to Joels but in a function-
Private Shared Function GetSheetNumber(ByVal SheetName As String) As String
        Return SheetName.Substring((SheetName.IndexOf(":") + 1))
    End Function
Then you can call many times like this to get the sheet number-
Dim SheetNo As Double = GetSheetNumber(oSheet.Name)
or
For Each oSheet As oDoc.Sheet in oDoc.Sheets
  MsgBox(GetSheetNumber(oSheet.Name)
Next
or
oDoc.Sheets(GetSheetNumber(oSheet.Name).Activate()
You can calculate the next sheet
oDoc.Sheets((GetSheetNumber(oSheet.Name) + 1).Activate
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 4 of 8
j.pavlicek
Thanks for reply! Your solution seems to be smart. But are you sure that number after ":" always correspond with Sheets.Item(Index)?
I want to be sure of that, to prevent desperate hunt for weird error in future.
PS: Also please correct type of SheetNo variable in your answer to some of integral types 😉
And the fourth example seems like oSheet.Activate with extra steps to me 🙂
Message 5 of 8
NachoShaw
Hi
The number after the : will always correspond with the number of the sheet even if some sheets have been excluded from the count, not necessarily with the index. I found personally that catching the actual sheet number instead of the index is more reliable
My bad on the integer types, by nature i always use a Double and as i typed this on my phone, i used a double without thinking..
Nacho
Message 6 of 8
j.pavlicek
@NachoShaw wrote:
... I found personally that catching the actual sheet number instead of the index is more reliable
Could you please specify, what exactly do you mean by "sheet number"? (iProperty, index in some collection, etc...). Thank you.
Message 7 of 8
NachoShaw
sheet numbers extracted direclty from the sheet name
Nacho
Message 8 of 8
dba78
maybe this?
'iLogic
Dim drw As DrawingDocument = ThisApplication.ActiveDocument
For i = 1 To drw.Sheets.Count
If (drw.ActiveSheet Is drw.Sheets(i))
	MsgBox("index: " & i)
Next
