How is this giving me a "Object variable or With block variable not set" error
AMN3161
Message 1 of 10
AMN3161
I know this is a very likely unnecessarily long and not optimized code but i am novice and still learning. This is how i know how to write code at this stage so bear with the chunkiness of the code
Ok so this is a long rule so I will post the relevant sections, right in the beginning of the rule i define a bunch of strings that i use throughout the rule
PartNumber1Desc = "Part Number 1 Description"
PartNumber2Desc = "Part Number 2 Description"
PartNumber3Desc = "Part Number 3 Description"
PartNumber4Desc = "Part Number 4 Description"
PartNumber5Desc = "Part Number 5 Description"
PartNumber1Vendor = "Part Number 1 Vendor"
PartNumber2Vendor = "Part Number 2 Vendor"
PartNumber3Vendor = "Part Number 3 Vendor"
PartNumber4Vendor = "Part Number 4 Vendor"
PartNumber5Vendor = "Part Number 5 Vendor"
PartNumber1PH = "Part Number 1 Place Holder"
PartNumber2PH = "Part Number 2 Place Holder"
PartNumber3PH = "Part Number 3 Place Holder"
PartNumber4PH = "Part Number 4 Place Holder"
PartNumber5PH = "Part Number 5 Place Holder"
 Now this section works perfectly with no errors
'[ 3-5 are Blank
If Not iProperties.Value("Custom", "Part_Number_1") = "" And Not iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
PartNumber1PH = iProperties.Value("Custom", "Part_Number_1")
PartNumber1PH =PartNumber1PH.Trim().ToUpper()
i = GoExcel.FindRow("P:\_MASTER_PART_LIST\MASTER_PART_LIST.xls", "MASTER_PART_LIST", "Part No.", "=", PartNumber1PH)
If i = -1
	PartNumber1Desc = "Bad Part Number 1"
	PartNumber1Vendor = "Bad Part Number 1"
	PartNumber1PH = "Bad Part Number 1"
Else
	PartNumber1Desc = GoExcel.CurrentRowValue("Description")
	PartNumber1Vendor = GoExcel.CurrentRowValue("Manufacturer")
	PartNumber1Desc = PartNumber1Desc.ToUpper()
	PartNumber1Vendor = PartNumber1Vendor.ToUpper()
PartNumber2PH = iProperties.Value("Custom", "Part_Number_2")
PartNumber2PH =PartNumber2PH.Trim().ToUpper()
i = GoExcel.FindRow("P:\_MASTER_PART_LIST\MASTER_PART_LIST.xls", "MASTER_PART_LIST", "Part No.", "=", PartNumber2PH)
If i = -1
	PartNumber2Desc = "Bad Part Number 2"
	PartNumber2Vendor = "Bad Part Number 2"
	PartNumber2PH = "Bad Part Number 2"
Else
	PartNumber2Desc = GoExcel.CurrentRowValue("Description")
	PartNumber2Vendor = GoExcel.CurrentRowValue("Manufacturer")
	PartNumber2Desc = PartNumber2Desc.ToUpper()
	PartNumber2Vendor = PartNumber2Vendor.ToUpper()
 iProperties.Value("Project", "Description") = PartNumber1Desc & " / " & PartNumber2Desc
 iProperties.Value("Project", "Vendor") = PartNumber1Vendor & " / " & PartNumber2Vendor
 iProperties.Value("Project", "Part Number") = PartNumber1PH & " / " & PartNumber2PH
Then I used that code to make another chunk of code that will run if 3 Custom Iproperties are not blank, the one above runs if 2 are blank
'[ 4-5 are Blank
If Not iProperties.Value("Custom", "Part_Number_1") = "" And Not iProperties.Value("Custom", "Part_Number_2") = "" And Not iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
If i = -1
Else
If i = -1
Else
PartNumber3PH = iProperties.Value("Custom", "Part_Number_3")
PartNumber3PH =PartNumber3PH.Trim().ToUpper()
i = GoExcel.FindRow("P:\_MASTER_PART_LIST\MASTER_PART_LIST.xls", "MASTER_PART_LIST", "Part No.", "=", PartNumber3PH)
If i = -1
	PartNumber3Desc = "Bad Part Number 3"
	PartNumber3Vendor = "Bad Part Number 3"
	PartNumber3PH = "Bad Part Number 3"
Else
	PartNumber3Desc = GoExcel.CurrentRowValue("Description")
	PartNumber3Vendor = GoExcel.CurrentRowValue("Manufacturer")
	PartNumber3Desc = PartNumber3Desc.ToUpper()
	PartNumber3Vendor = PartNumber3Vendor.ToUpper()
 iProperties.Value("Project", "Description") = PartNumber1Desc & " / " & PartNumber2Desc & " / " & PartNumber3Desc
 iProperties.Value("Project", "Vendor") = PartNumber1Vendor & " / " & PartNumber2Vendor & " / " & PartNumber3Vendor
 iProperties.Value("Project", "Part Number") = PartNumber1PH & " / " & PartNumber2PH & " / " & PartNumber3PH
but I am getting a "Object variable or With block variable not set", I don't understand i made it from a working piece of code and it just adds another custom iproperty to the code but mechanically does the same thing as the working rule
Am i missing something really stupid here?
Replies (9)
Message 2 of 10
J-Camper
This is hard to troubleshoot without your existing data set.  If you can post more of the code and/or any similar files, it would make troubleshooting easier.  DO NOT POST ANY CONFIDENTIAL FILES!!
However, if you sprinkle messageboxs throughout the codes like this:
'your code does tasks
MessageBox.Show("Code executes to here.", "Debug 1")
'Your code does more tasks
MessageBox.Show("Code executes to here.", "Debug 2")
MessageBox.Show("Code executes to here.", "Debug 3")
You should be able to narrow down the line which is throwing the error.
Message 3 of 10
AMN3161
Here is the entire rule, i had it build all of the iproperties it needs so it can be put onto a blank part and work.
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim MyArrayList As New ArrayList
MyArrayList.Add("Part_Number_1")
MyArrayList.Add("Part_Number_2")
MyArrayList.Add("Part_Number_3")
MyArrayList.Add("Part_Number_4")
MyArrayList.Add("Part_Number_5")
oCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
'[ Adds custom properties
For Each oItem In MyArrayList
	oFlag = False 'set flag to default value
	'look at each property in the collection
	For Each oCustProp In oCustomPropertySet
		'check property name against the list item
		If oItem = oCustProp.Name Then
			oFlag = True 'trip the flag
	Next
	If oFlag = False Then
		'Create new iProperty
		iProperties.Value(oDoc, "Custom", oItem ) = ""
Next
'[ Erases custom properties
		If oCustProp.Name = oItem Then
	Next
		'delete property
		oCustProp.Delete
Next
'[ 1-5 are Blank
If iProperties.Value("Custom", "Part_Number_1") = "" And iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
Dim partNumber As String = iProperties.Value("Project", "Part Number")
partNumber = partNumber.Trim().ToUpper()
i = GoExcel.FindRow("P:\_MASTER_PART_LIST\MASTER_PART_LIST.xls", "MASTER_PART_LIST", "Part No.", "=", partNumber)
If i = -1
	iProperties.Value("Project", "Description") = "The entered Part Number does not exist in the Master Parts List"
	iProperties.Value("Project", "Vendor") = "The entered Part Number does not exist in the Master Parts List"
Else
	iProperties.Value("Project", "Description") = GoExcel.CurrentRowValue("Description")
	iProperties.Value("Project", "Vendor") = GoExcel.CurrentRowValue("Manufacturer")
	Dim partDescription As String = iProperties.Value("Project", "Description")
	partDescription = partDescription.ToUpper()
	iProperties.Value("Project", "Description")= partDescription
	Dim partVendor As String = iProperties.Value("Project", "Vendor")
	partVendor = partVendor.ToUpper()
	iProperties.Value("Project", "Vendor") = partVendor
'[ 2-5 are Blank
If Not iProperties.Value("Custom", "Part_Number_1") = "" And iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
PartNumber1PH = PartNumber1PH.Trim().ToUpper()
If i = -1
Else
	PartNumber1Desc= iProperties.Value("Project", "Description")
	iProperties.Value("Project", "Description")= PartNumber1Desc
	PartNumber1Vendor = iProperties.Value("Project", "Vendor")
	iProperties.Value("Project", "Vendor")= PartNumber1Vendor
'[ 3-5 are Blank
If i = -1
Else
If i = -1
Else
'[ 4-5 are Blank
If i = -1
Else
If i = -1
Else
If i = -1
Else
Message 4 of 10
AMN3161
but let me try that message box idea real fast
Message 5 of 10
AMN3161
Ok from what i can tell is that the portion that i last added works in isolation, so i starting cutting portions out of my code to see where the interference is and this is what i narrowed it down to
'[ 4-5 are Blank
If i = -1
Else
If i = -1
Else
If i = -1
Else
This is my new portion above and it works in isolation, if I remove this (below) out of my code existing code, then the portion (above) works
'[ 3-5 are Blank
If i = -1
Else
If i = -1
Else
So basically my "4-5 are Blank" portion will work in isolation and will also work only if "3-5 are Blank" is removed from the rule. There is something between those two portions that are not happy with each other. But "3-5 are Blank" will work fine when "4-5 are Blank" is in there, just not vice versa
Message 6 of 10
AMN3161
Ok so if I switch order of  "4-5 are Blank" and "3-5 are Blank" in the rule, then "4-5 are Blank" works and "3-5 are Blank  doesn't now
I don't get what can be causing this problem
Message 7 of 10
J-Camper
I think it might work better if you tie the (1-5 are blank), (2-5 are blank), etc. into a single If, Else If Statement.  I made that change, so try this:
	Next
Next
	Next
		'delete property
		oCustProp.Delete
Next
'[ 1-5 are Blank
'End If
If i = -1
Else
'[ 2-5 are Blank
Else If Not iProperties.Value("Custom", "Part_Number_1") = "" And iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
'End If
If i = -1
Else
'[ 3-5 are Blank
Else If Not iProperties.Value("Custom", "Part_Number_1") = "" And Not iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
'End If
If i = -1
Else
'If Not iProperties.Value("Custom", "Part_Number_1") = "" And Not iProperties.Value("Custom", "Part_Number_2") = "" And iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
'End If
If i = -1
Else
'End If
'[ 4-5 are Blank
Else If Not iProperties.Value("Custom", "Part_Number_1") = "" And Not iProperties.Value("Custom", "Part_Number_2") = "" And Not iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
'End If
If i = -1
Else
'If Not iProperties.Value("Custom", "Part_Number_1") = "" And Not iProperties.Value("Custom", "Part_Number_2") = "" And Not iProperties.Value("Custom", "Part_Number_3") = "" And iProperties.Value("Custom", "Part_Number_4") = "" And iProperties.Value("Custom", "Part_Number_5") = "" Then
'End If
If i = -1
Else
'End If
If i = -1
Else
I know you mentioned the code is chunky because you are new to coding, but if you would like I could condense this into something more streamlined.  I would be sure to leave plenty of comments which might make more sense once you see it, but I don't want to waste my time if you want to stick with what you are comfortable with.
Message 8 of 10
AMN3161
No please, i would love to know how to make it more streamline. I have much more to add to this and i would love a method to make this more condensed.
Its a breath of fresh air when I learned you can do this '[ '] to make collapsible segments of code
Message 9 of 10
J-Camper
Okay, I will spend some time later today on it and get back to you.
Message 10 of 10
J-Camper
I've been tinkering and this is what i have:
Sub Main 'Where main code lives
	Dim oDoc As Document = ThisDoc.Document
	Dim MyArrayList As New List(Of String)
	MyArrayList.AddRange({"Part_Number_1", "Part_Number_2", "Part_Number_3", "Part_Number_4", "Part_Number_5"}) '{Brackets Create Range. Seperated by commas}
	'[Adds custom properties
		Next
			iProperties.Value(oDoc, "Custom", oItem) = ""
	Next
	'[Erases custom properties
	'I don't really recomend deleting every Custom iProperty in case you want to use more later down the line
		Next
			'delete property
			oCustProp.Delete
	Next
	'[Determine which Part Numbers Are filled in:
	Dim ActiveItems As New List(Of Boolean) 'First item is i = 0 and last item is i = List.Count - 1
	ActiveItems.AddRange({True, True, True, True, True})
	Dim ActiveCount As Integer = 0
	For j As Integer = 0 To MyArrayList.Count - 1
		If oCustomPropertySet.Item(MyArrayList.Item(j)).Value = ""
			ActiveItems.Item(j) = False
		Else
			ActiveCount += 1
	Next
	'[Set Part Number, Description, Vendor
	Dim partNumber As String = ""
	'I've always had a hard time getting "GoExcel.FindRow" to work in the past, but if it is working then I won't change it.  I just wasn't able to test the GoExcel commands
	If ActiveCount = 0 'All are empty
		partNumber = iProperties.Value("Project", "Part Number").ToString.Trim().ToUpper()
		If i = -1
		Else
			iProperties.Value("Project", "Description") = GoExcel.CurrentRowValue("Description").ToString.ToUpper()
			iProperties.Value("Project", "Vendor") = GoExcel.CurrentRowValue("Manufacturer").ToString.ToUpper()
	Else If ActiveCount = 1 'Only 1 is not empty
		partNumber = iProperties.Value("Custom", MyArrayList.Item(ActiveItems.IndexOf(True))).ToString.Trim().ToUpper()
		If i = -1
		Else
	Else 'More than 1 is not empty
		'Setup Combo Strings
		Dim BuildPartNumber As String = ""
		Dim BuildDescription As String = ""
		Dim BuildVendor As String = ""
		'Build Per String
		For k As Integer = 0 To ActiveItems.Count - 1
			If ActiveItems.Item(k) = True
				partNumber = iProperties.Value("Custom", MyArrayList.Item(k)).ToString.Trim().ToUpper()
				If i = -1
					BuildPartNumber = AddToString(BuildPartNumber, "Bad Part Number " & (k+1).ToString)'Calling a custom function
					BuildDescription = AddToString(BuildDescription, "Bad Part Number " & (k+1).ToString)'Calling a custom function
					BuildVendor = AddToString(BuildVendor, "Bad Part Number " & (k+1).ToString)'Calling a custom function
				Else
					BuildPartNumber = AddToString(BuildPartNumber, partNumber)'Calling a custom function
					BuildDescription = AddToString(BuildDescription, GoExcel.CurrentRowValue("Description").ToString.ToUpper())'Calling a custom function
					BuildVendor = AddToString(BuildVendor, GoExcel.CurrentRowValue("Manufacturer").ToString.ToUpper())'Calling a custom function
		Next
		'Set Properties
		iProperties.Value("Project", "Description") = BuildDescription
		iProperties.Value("Project", "Vendor") = BuildVendor
		iProperties.Value("Project", "Part Number") = BuildPartNumber
End Sub 'Where main code lives
Function AddToString(Source As String, Addition As String) As String
	If Source = "" 'First Time Running
		Result = Addition
	Else
		Result = Source & " / " & Addition
	Return Result
End Function
I never had any luck getting "GoExcel.FindRow" to find my column names in the past, I'm not sure why...  Anyways I didn't want to change that if it is working for you.  So The only thing I couldn't test was grabbing the data from the excel file.
Let me know if you have any questions, or it is not working as intended.
