iLogic -How to extrude specific profiles
etrejoAE79M
etrejoAE79M
Question: Is it possible to code which profiles (blocks) from one single sketch to extrude? One sketch with multiple block profiles using one extrusion command to extrude the profiles. I want to create  code that specifically picks which profiles (blocks) to extrude from that single extrusion command. Is this possible?
dgreatice
yes it can, but now how you select that profile for usig in extrude?
using area of profile?
manually is user selection.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
etrejoAE79M
Yes the area of one block i am using. is there like a snippet or line of code to where you can pick which profiles to use for that extrusion?
dgreatice
hi,
can you provide you 2D Sketch? attach here
