HRESULT: 0x80004005 while run external iLogic on one of the two IPTs
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I have attached couple IPTs (first is referencing the second as Derived).
I wonder why I'm getting "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))" when running single-line external iLogic (supposed just to show the name of material) on one of them?
MsgBox (ThisDoc.Document.ComponentDefinition.Material.Name,,"Part's material name is:     ")
If it possible to recompose this rule in a way compatible with both IPTs?
Please vote for Inventor-Idea Text Search within Option Names
frederic.vandenplas
Hi @Maxim-CADman77
This is plain vba code that i "converted" to iLogic
Vba:
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
MsgBox (oDoc.ActiveMaterial.DisplayName)
iLogic:
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Maxim-CADman77
I can confirm - MsgBox with material name now appears for both IPTs. Thus the initial issue is solved but ... still Error 80004005 pops if iLogic editor is opening while Angle_MIR part is active.
Seems like Angle_Mir.ipt is somehow defected, right?
MjDeck
Angle_MIR.ipt is a sheetmetal part, but it has no sheetmetal parameters. That's what causes the iLogic error. It also seems to be missing other things that would make it a useful sheet metal part. Notice that you can't create sheet metal features or a flat pattern. The part was created in Inventor R10, and it's possible that the component mirror operation at that time did not properly use the sheet metal template. The part units are centimeters, and that might mean that it was created with no template at all.
If you can, I'd recommend deleting it and creating a new mirrored part from Angle.ipt.
Mike Deck
Software Developer
Autodesk, Inc.
Maxim-CADman77
Thank you, Mike!
PS: Hope you can also look at this thread - https://forums.autodesk.com/t5/inventor-customization/occasional-quot-object-variable-or-with-block-...
