iLogic: how to do "regenerate all rules" for all open idw documents.
boris
Message 1 of 8
boris
Hi, how to do "regenerate all rules" for all open idw documents with ilogic or vba?
I tried to make a rule but it doesn’t work
   Dim oDoc As Document
    For Each oDoc In ThisApplication.Documents.VisibleDocuments
        If oDoc.DocumentType = kDrawingDocumentObject Then
		  iLogicVb.UpdateWhenDone = True
		  Dim controlDef As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("iLogic.RegenAllRules")
controlDef.Execute2(True)
        End If
    Next oDoc
Thanks in advance!
Replies (7)
Message 2 of 8
JhoelForshav
@boris
Perhaps something like this? 🙂
For Each oDoc As Document In ThisApplication.Documents.VisibleDocuments
		For Each oRule As iLogicRule In iLogicVb.Automation.Rules(oDoc)
			If oRule IsNot iLogicVb.Automation.GetRule(iLogicVb.RuleDocument, iLogicVb.RuleName) 'Make sure not to create an infinity loop!
				iLogicVb.Automation.RunRuleDirect(oRule)
			End If
		Next
	End If
Next
Message 3 of 8
boris
Code not work 😞 inventor 2018
Rule Compile Errors in ilogic - update all opened documents with ilogic rules, in test.idw
Error on Line 4 : 'RuleName' is not a member of 'Autodesk.iLogic.Interfaces.ILowLevelSupport'.
What rule name should I enter?
Message 4 of 8
JhoelForshav
Apparently RuleName method wasn't available in Inventor 2018. I cannot think of any other way to keep the rule from running itself over and over again if it exists in a drawing document then....
You could run it like this though... Just make sure not to run it from a drawing document!
		Next
	End If
Next
Message 5 of 8
JhoelForshav
Or if you name your rule something specific and have that name hard coded in the rule like this maybe?
It's very important that you name the rule RegenRules in this case.
			If oRule IsNot iLogicVb.Automation.GetRule(iLogicVb.RuleDocument, "RegenRules") 'Make sure not to create an infinity loop!
			End If
		Next
	End If
Next
Message 6 of 8
Darkforce_the_ilogic_guy
are the rules on the doc or extranel rules?
Message 7 of 8
boris
code works in new idw file 🙂
Thanks you.
What would such code look like for working with assemblies?
launching rules both in assembly and in subassemblies and parts.
Message 8 of 8
boris
create new.idw
create rule in new.idw
insert code
		Next
	End If
Next
 run rule.
profit 🙂
