Ilogic-How to choose plane and point iFeature (code)
Message 1 of 8
I want insert iFeature into Part. But i don't know code choose Plane and Point. Please help me!!!Capture.PNG
Replies (7)
Message 2 of 8
Michael.Navara
Message 3 of 8
Thank you.
But it isn't " Pick Point" . I dont know define Point Refence iFeature. Can help me!!!
Message 4 of 8
Michael.Navara
Full example is in attachment
'Active part
Dim partDoc As PartDocument = ThisDoc.Document
Dim partDef As PartComponentDefinition = partDoc.ComponentDefinition
'Placement sources
Dim oSketch As PlanarSketch = partDef.Sketches("iFeatureTargetSketch")
Dim oFace As Face = oSketch.PlanarEntity
Dim oPoint As SketchPoint = oSketch.SketchPoints(1)
'iFeature creation
Dim iFeatureFileName As String = System.IO.Path.GetDirectoryName(partDoc.FullFileName) & "\Test.ide"
Dim iFeatureDef As iFeatureDefinition = partDef.Features.iFeatures.CreateiFeatureDefinition(iFeatureFileName)
For Each iFeaInput As iFeatureInput In iFeatureDef.iFeatureInputs
	'Explanation. See iLogic log window
	Logger.Debug("Expected entities for " & iFeaInput.Name & ": " & vbCrLf  & iFeaInput.EntityType.ToString("F").Replace(", ", vbCrLf))
	Select Case iFeaInput.Name
	Case "Plane"
		Dim planeInput As iFeatureSketchPlaneInput = iFeaInput
		planeInput.PlaneInput = oFace
	Case "Point"
		Dim pointInput As iFeatureEntityInput = iFeaInput
		pointInput.Entity = oPoint
	End Select
Next
partDef.Features.iFeatures.Add(iFeatureDef)
Message 5 of 8
Thanks . I tried my best. But it's buggy, I don't fix them. I am using Inventor 2019 so I can't open your file. I send you my file. Can you check it out for me? Rules = iFeature
code
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oPartDef As PartComponentDefinition
oPartDef = oPartDoc.ComponentDefinition
Dim oPlane As WorkPlane = oPartDef.WorkPlanes.Item("YZ Plane")
Dim oPoint As WorkPoint = oPartDef.WorkPoints.Item("Center Point")
Dim oFeatures As PartFeatures
oFeatures = oPartDef.Features
Dim oiFeatureDef As iFeatureDefinition
oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\Users\Public\Documents\Autodesk\Inventor 2019\Catalog\TAVO\LINK PIPE\DN125SCH40.ide")
Dim oInput As iFeatureInput
For Each oInput In oiFeatureDef.iFeatureInputs
Dim oParamInput As iFeatureParameterInput
Select Case oInput.Name
Case "Plane1"
Dim oPlaneInput As iFeatureSketchPlaneInput=oInput
oPlaneInput.PlaneInput = oPlane
Case "Point1"
Dim pointInput As iFeatureEntityInput = oInput
Case "Angle_position"
oParamInput = oInput
oParamInput.Expression = "90 deg"
Case "Lenght_pipe"
oParamInput.Expression = "200 mm"
Case "Position_hold"
oParamInput.Expression = "500 mm"
Case "R_tank"
oParamInput.Expression = diameter/2
Case "Thick"
oParamInput.Expression = Thickness
End Select
Next
Dim oiFeature As iFeature
oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
Message 6 of 8
Michael.Navara
You need to set appropriate variable type.
Here is the change
    Case "Plane1"
        'This iFeatureInput is iFeatureWorkPlaneInput (NOT iFeatureSketchPlaneInput)
        Logger.Debug(oInput.Type.ToString("F"))
        Dim oPlaneInput As iFeatureWorkPlaneInput = oInput
The second bug is in setting .Expression. This must be a string (NOT double) and unit specifier is recomended
Case "R_tank"
    oParamInput.Expression = string.format("{0} mm", diameter/2 *10) ' diameter
Case "Thick"
    oParamInput.Expression =  string.format("{0} mm", Thickness *10) 'Thickness
Message 7 of 8
That is a wonderful thing for me. Thank you very much. I have a question, I don't know if that variable exists. how do I know the variable name. While writing code on Inventor it does not show variable options. For example, I know the face I selected is Plane but I don't know the variable named iFeatureWorkPlaneInput. Can you share your experiences and materials? Once again thank you very much.
Message 8 of 8
Michael.Navara
Documentation for Inventor API is available locally in SDK or online
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-6FD7AA08-1E43-43FC-971B-5F20E56C8846
I use VBA tools (Locals and Watch windows) for better understanding of object structure. This tools are very handy.
For general information for VB.NET I use standard sources (MSDN, StackOverflow,...)
But experience is not shareable 😐
