how do i save tooltip
Darkforce_the_ilogic_guy
Advisor Advisor
I have this code
Public Sub Addtoolstips()
Dim a As Application
Set a = ThisApplication
Dim MCDDefaultUser As MacroControlDefinition
Set MCDDefaultUser = a.CommandManager.ControlDefinitions.Item("Macro:TimeTable.TimeTable")
'MsgBox (MCDDefaultUser.ProgressiveToolTip.ExpandedDescription)
MCDDefaultUser.ProgressiveToolTip.ExpandedDescription = "Vil åbne den nyeste tidsplan som er tilgængelig dog max gå en uge tilbage"
'MCDDefaultUser.ProgressiveToolTip.Image = "C:\Files\YourImage.jpg"
Set MCDDefaultUser = a.CommandManager.ControlDefinitions.Item("Macro:RefreshColour.RefreshColour")
MCDDefaultUser.ProgressiveToolTip.ExpandedDescription = "Text 1"
' PDF Draft
Set MCDDefaultUser = a.CommandManager.ControlDefinitions.Item("Macro:PDFDraft.PDFDraft")
MCDDefaultUser.ProgressiveToolTip.ExpandedDescription = "text 2"
End Sub
the code work .. I can see tooltips I want after it have been run .... but there are not there when inventor is restarted
is there a why to save it ?... and what file is this information save in ?
FINET_Laurent
Morning,
Maybe triggering the macro each time you start inventor is a solution ?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
how do I triggering the macro each time you start inventor
FINET_Laurent
Didn't find any answer to that.. >.<
