Ilogic Help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm involved in a massive task updating my company system evolving from AutoCAD LT to Inventor. My task consisted of preparing a series of "3D Templates" with a certain level of automation. I've got some basic skills in iLogic and so far I manage to diminish the level of future users interactions with this "3D Templates" using forms etc. Due to the innevitable connection between the "_control.ipt" part to drive the majority of equations etc, the assembly iProperties needs to be connected in order to fill up the specification table on the drawings. Using this Forum and the vast experience of this incredible community I manage to solve a few issues others I need to come back to anyone can help.
The problem: Im exporting all my parameters in the control via logic in that way I can export Text/Multivalue parameters. one piece of code (first image) copy all the parameters to the iproperties is a long piece of code in my opinion not efficient piece of code, however this code maintains the functionality that once I change a parameter it will automatically update the iproperties. The second image (image_02) is more efficient code I guess but it has come to my attention that eveytime I modify a parameter I have to run the rule manually in order to update the value of the iproperties, which is crazy! Any magic from you guys to help me see the solution of this it will be very well appretiated.
kind regards and thanks in advance for your help
my email address: [email protected]
