@Anonymous wrote:
Many thanks to all contributers as always... the code works well to do what it does but if you are dropping these views and parts lists onto idw's, each time you run the rule on a different view rep in the assemble it changes the occurances of the previous view rep so your data on the idw is wrong again...
i may be missing something but i am after, (the same as the original post)
http://forums.autodesk.com/t5/Autodesk-Inventor/View-representation-parts-list-error/m-p/3606706/highlight/false
Im guesing this is not possible still without using the dreaded iassemblies or splitting the original assembly into lots of sub assemblies
Hi all,
I have the same issue, I am making a door frame which I can use for both a swing and sliding door.
The main frame set-up is usable for both but some parts are specific to the versions and of course the parts for a swing door should not show up in the sliding door BOM and vice versa.
What I would like is to have a seperation between the 2 preferably not using the LOD, so that I can use this one assembly for both versions but the BOM of the doors displaying the correct parts.
But I find this very unreliable because everytime I run this rule the part list in the DWG is updated to the one which is active in the IAM itself.
We are a few years further now is there a proper solution found in the meantime?
Kind regards,
Aram.
