iLogic help + Accessing the File name of a referenced document.
MechMachineMan
Advisor Advisor
MechMachineMan
I'm trying to make a list of all referenced / referencing documents and currently all it does is show up blank, as if it is skipping over the whole For section.
Please take a look and advise me on what I'm doing wrong.
SubMain()
oWrite = System.IO.File.CreateText("C:\Users\FILE NAME HERE"&".txt")
oDoc=ThisDoc.Document
Fori=1To 100
    oWrite.WriteLine(i)
    Next
Forj=1TooDoc.AllReferencingDocuments.Count
    DimoRefAsDocument = oDoc.AllReferencingDocuments.Item(j)
    oWrite.WriteLine(oRef.FullFileName)
    Next
oWrite.Close
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
rossano_praderi
Hi, I think this can be your solution...
Sub Main()
oWrite = System.IO.File.CreateText("d:\test.txt") ' Change the filename as you like
oDoc = ThisDoc.Document
For j = 1 To oDoc.AllReferencedDocuments.Count
    oWrite.WriteLine(j & ") " & oDoc.AllReferencedDocuments.Item(j).FullFileName)
Next
' ******* if you want the first level referenced documents then this is your option *********
'For j = 1 To oDoc.AllReferencedDocuments.Count
'    oWrite.WriteLine(j & ") " & oDoc.AllReferencedDocuments.Item(j).FullFileName)
'Next
oWrite.Close
End Sub
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
rossano_praderi
I made a mistake...this is the correction for part of my posted code....sorry.
'For j = 1 To oDoc.ReferencedDocuments.Count
'    oWrite.WriteLine(j & ") " & oDoc.ReferencedDocuments.Item(j).FullFileName)
'Next
Bregs
Rossano Praderi
MechMachineMan
Thanks! That seems to have done it. Was getting random Invalid errors because my indexing was off, then was not printing any info due to me using the wrong document object/referencing.
Now that it's working... Time to figure out how to put it in a drawing table!
Justin K
rossano_praderi
Hi, I'm glad to be helpful.
Bregs
Rossano Praderi
