iLogic, function for virtual components
justinparfitt
justinparfitt
Could you please help me out and advise, where do I miss additional code with ComponentOccurance  or Add.Virtual item.
When configurator is run and door reach height of 2500mm, I would like to add virtual item "FLUSHBOLT EXTENDED ROD"
If leaf_height >= 2500 Then
AddAdditionalItems(oAsmDoc,1, "FLUSHBOLT EXTENDED ROD", "FLUSHBOLT EXTENDED ROD")
 It works, but then I have another instance where, if another parameter is true then:
AddAdditionalItems(oAsmDoc,1, "PACKER FOR EXTERNAL DEVICE", "PACKER FOR EXTERNAL DEVICE")
And at this point both virtual items are PACKER FOR EXTERNAL DEVICE:1 and PACKER FOR EXTERNAL DEVICE:2
Please see code below:
Function AddAdditionalItems(asmDoc As AssemblyDocument, ItemQuantity As Double, ItemNameOnDrawing As String, ItemNameDescription As String) As String
	QTY = ItemQuantity
	'Dim asmDoc As AssemblyDocument
    asmDoc = ThisDoc.ModelDocument
    Dim oOccs As ComponentOccurrences
    oOccs = asmDoc.ComponentDefinition.Occurrences
    ' Create collection to hold virtual parts
    Dim oVPs As ObjectCollection
    oVPs = ThisApplication.TransientObjects.CreateObjectCollection
    ' Add to collection of virtual parts
    For Each oOcc As ComponentOccurrence In oOccs
        If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
            oVPs.Add(oOcc)
        End If
    Next
    Dim identity As Matrix = ThisApplication.TransientGeometry.CreateMatrix
    Dim virtOcc As ComponentOccurrence
    If oVPs.Count > 0 Then
        virtOcc = oVPs.Item(1)
    Else
        virtOcc = oOccs.AddVirtual(ItemNameOnDrawing, identity)
        ' Set properties of virtual part
        'iProperties.Value(virtOcc.Name, "Project", "Part Number") = "INSERT PART NUMBER HERE"
        iProperties.Value(virtOcc.Name, "Project", "Description") = ItemNameDescription
        'iProperties.Value(virtOcc.Name, "Project", "Stock Number") = "INSERT STOCK NUMBER HERE"
        oVPs.Add(virtOcc)
    End If
	  ' Compare actual to required
    If QTY > oVPs.Count Then ' Add more virtual parts
        For aaa = 1 To QTY - oVPs.Count
            Call oOccs.AddByComponentDefinition(virtOcc.Definition, identity)
        Next
    Else If QTY < oVPs.Count ' Remove virtual parts
        RemoveQTY = oVPs.Count - QTY
        For bbb = oVPs.Count To QTY + 1 Step -1
            oVPs.Item(bbb).Delete
        Next
    End If
End Function
Thanks...
Zach.Stauffer
I couldn't quite figure out why your code wasn't working, the logic is a little confusing. I think you are selecting any virtual part instead of selecting only virtual parts that have the same name as the one you are trying to add. However I wasn't sure of that so I tried to simplify your function to do what I think you want. Give it a try and see:
Sub Main
	Dim assemblyDoc = ThisApplication.ActiveDocument
	AddAdditionalItems(assemblyDoc, 4, "FLUSHBOLT", "FLUSHBOLT")
	AddAdditionalItems(assemblyDoc, 2, "PACKER", "PACKER")
End Sub
Function AddAdditionalItems(assemblyDoc As AssemblyDocument, ItemQuantity As Double, ItemNameOnDrawing As String, ItemNameDescription As String) As String
    Dim assemblyOccurrences As ComponentOccurrences = assemblyDoc.ComponentDefinition.Occurrences
	Dim numVirtualParts As Integer = 0
	Dim existingVirtualPart As ComponentOccurrence
	For Each componentOcc As ComponentOccurrence In assemblyOccurrences
		If componentOcc.Name.Contains(ItemNameOnDrawing) Then
			existingVirtualPart = componentOcc
			numVirtualParts += 1
		End If
	Next
	If numVirtualParts = 0 Then
		existingVirtualPart = assemblyOccurrences.AddVirtual(ItemNameOnDrawing, identity)
	End If
	If numVirtualParts < ItemQuantity
		Dim nextPartNumber As Integer = numVirtualParts + 1
		Dim finalPartNumber As Integer = ItemQuantity
		For i As Integer = nextPartNumber To finalPartNumber Step 1
    		Dim virtOcc As ComponentOccurrence = assemblyOccurrences.AddByComponentDefinition(existingVirtualPart.Definition, identity)
		Next
	End If
	If numVirtualParts > ItemQuantity Then
		While numVirtualParts > ItemQuantity
			For i = 1 To assemblyOccurrences.Count
				If assemblyOccurrences(i).Name.Contains(ItemNameOnDrawing)Then
					assemblyOccurrences(i).Delete()
					numVirtualParts -= 1
					Exit For
				End If
			Next
		End While
	End If
End Function
Instead of adding multiple virtual parts you could investigate changing the BOM to reflect the correct quantity, that might be a better approach in the long run.
justinparfitt
Hi Zach,
Thank you very much for re-writing the function.
The items are coming now as individual components, but the iProperty description do not get filled in.
When item quantity is set to 2 and more the description is bang on, but it doesn't do it with 1 item.
Could you please have a look, when you got a minute?
Thanks...
Zach.Stauffer
Just forgot to add that part where it adds the description for single parts:
	iProperties.Value(existingVirtualPart.Name, "Project", "Description") = ItemNameDescription
End If
justinparfitt
Thank you very much!
