iLogic Forms Picture Folder?
meck
meck
What is it for and how do I use it?
Will it allow me to switch between different pictures for display on my iLogic form?
If so? How do I set which picture to display?
Where can I get more in depth help on this stuff?????
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
MjDeck
When you drag in a Picture Fodler object, it contains two Picture objects.  You can add more.
- Click on each Picture object, click on the Image property and browse to a bitmap file.
- Change the Label (name) of each Picture object to something meaningful.
- Create a Text parameter (named PictureName or something similar) in your part or assembly.  Make it a multi-value parameter.  Set the possible values to be the same as the labels (names) of the Picture objects that you have just named.
- Add another Picture object to your form.  Add it outside of the Picture folder.  This will be a visible object, shown on the form.
- Click on the Picture Parameter Name property of that new Picture object.  Set it to the name of your Text parameter (PictureName in this example).
 Then you can use a rule to drive the value of the PictureName parameter.  This will change the image in the form.
Mike Deck
Software Developer
Autodesk, Inc.
meck
Thanks Mike!
Mike Eck
Using Inventor 2018
Hi all,
 I have a similar problem to this. Can I switch between the images by selecting difrent tabs in my form ? I want to update the image by the selected tab. capture.png
I have tried "if" or "select case" and neither one worked. as I am saying Stair_Properties = True it only makes the tab active. It doesnt indicate if it is selected, here is the code :
If Stair_Properties = True Then
Image = "Image 01"
End If
If Railing_Properties = True Then
Image = "Image 02"
End If
If Riser_Properties = True Then
Image = "Image 03"
End If
'Select Case Image
'Case Stair_Properties
'Image = "Image 01"
'Case Railing_Properties
'Image = "Image 02"
'Case Riser_Properties
'Image = "Image 03"
'End Select
Any help would be great...
meck
There are no events to trigger the switch of a picture by clicking on a tab. What I would do is place a picture on each tab with what I way to convey.
Mike Eck
Using Inventor 2018
