Ilogic Form, spacing buttons
Can anyone help to reduce the space between the buttons on the forms.
bhavik4244
@Anonymous
you may change the size limit.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Bhavik Suthar
LinkedIn
Bhavik Suthar
dutt.thakar
@Anonymous
You can restrict the size of buttons from size limits by editing the form and selecting the specific button. You can put maximum and minimum sizes in pixels and em. You can also use empty spaces and splitters.
See the below snapshots.
Check out the below link for a more descriptive overview of Forms by Ketiv Technologies on youtube.
https://www.youtube.com/watch?v=mq5lxC4BdJ4
Hope this will be helpful.
Dutt Thakar
LinkedIn
I'm using  "Global Forms". I can not change the Size limits.
Gr,
Lennard
dutt.thakar
@Anonymous
As long as you have the right to edit (it should not be in read only or locked in vault) the global form you are allowed to change the size limits. The snaps I attached are from global form only.
I also tested with one of my global from and I am allowed to edit.
Dutt Thakar
LinkedIn
Thanks😀
