iLogic Form, Label size
Mathias_CompC
Mathias_CompC
Control vs. Label sizeControl vs. Label size
 I need a few minutes of being humbled in my ignorance of an obvious answer.
When designing a form, I quite often end up changing the lables to a parameter control, to 'x', like the example provided.
How can you limit/change the size of the label?!?
"Size limits" are strictly tied to the size of a control...
Thanks in advance for any helpful comments.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Mathias_CompC,
Hoping that font of label will help to change size of label as shown in below image.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Mathias_CompC
Oh, I'm sorry if I misled you, it is not an actual label.
It is the label part of a parameter control. If you look at my original img, the 'x' is the label connected to the control ProfilBredd. If I change the sizeLimits of that...
Let me post another screenshot. I marked the area I want to control in red, as well as the line in the form design window
chandra.shekar.g
Autodesk Support
Autodesk Support
@Mathias_CompC,
Can you please provide sample part with iLogic form to test? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Mathias_CompC
Sure 😃
chandra.shekar.g
Autodesk Support
Autodesk Support
@Mathias_CompC,
By adding Group to iLogic form, helped to resize 'x' parameter.
Modified part is also attached with this post.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Mathias_CompC
That... worked 😃
Thank you so much Smiley Very Happy
