iLogic Form checkbox to turn a set of features on/off
tjg86f
tjg86f
I am trying to make an iLogic form that can basically turn a set of features on/off with a check box instead of having separate buttons to suppress all of the features. The model will have multiple "configurations" that all start visible so I would like to use these check boxes to pick which configs to turn off or on. The reason I want this in checkbox form is so I can conditionally turn off other fields in the iLogic form based off the suppression status of each config (turning off dimension fields for all configs besides the active config) to hopefully make the form more user friendly.
CCarreiras
HI!
I guess you can't turn off fields in the form (let´s say... turn a field visible or invisible).
I use tabs to separate the fields: if the field is on, I complete the rest of the parameters, if it is off, I go to the next... but they are always visible.
CCarreiras
tjg86f
This is where I'm at right now. (Config 1 & Config 2 correspond to the smaller and bigger "C" shapes respectively). For reference, How would I go about putting "tabs" into a form like this?
CCarreiras
Create the tabs and then drag the fields into the respective tab.
CCarreiras
CCarreiras
Observing your form, i suppose you only need two tabs (config 1 and config 2) and two buttons (on/off).
CCarreiras
