Here is the whole code it is to take an assembly and make a mold using derive.
I was taking bits and parts of it to make what I need but I FAIL
Public Sub MoldBaseSample()
' Initialize the string that defines the directory where the
' files will be created.
Dim sFilePath As String
sFilePath = "C:\Temp\"
' Call the functions to create the parts that represent the
' molded part and the mold base.
Call CreateMoldPart(sFilePath & "MoldPart.ipt")
Call CreateMoldBase(sFilePath & "MoldBase.ipt")
' Create a new part file to derive the mold part in.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Create a derived definition for the molded part.
Dim oDerivedPartDef As DerivedPartUniformScaleDef
Set oDerivedPartDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(sFilePath & "MoldPart.ipt")
' Set the scale to use.
oDerivedPartDef.ScaleFactor = 1.1
' We could set other options for the derived part using the derived part definition.
' In this case the defaults are good except for the scale which we changed.
' Create the derived part.
Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
' Save and close the part.
Call oPartDoc.SaveAs(sFilePath & "ScaledMoldPart.ipt", False)
oPartDoc.Close
' Create a new assembly file to put the mold base and scaled part together.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.Documents.Add(kAssemblyDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kAssemblyDocumentObject))
' Create the matrix used to define the position of the occurrences. When a new
' matrix is created it is initialized to an identity matrix. This will cause
' parts to be placed into the assembly in the same location that are in part space.
Dim oMatrix As Matrix
Set oMatrix = ThisApplication.TransientGeometry.CreateMatrix
' Place the mold base.
Dim oOcc As ComponentOccurrence
Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "MoldBase.ipt", oMatrix)
' Rename the occurrence. This sample uses the name to identify the occurrence later.
' This isn't the only method that could be used, but is one of the simplest.
oOcc.Name = "Mold Base"
' Place the scaled part.
Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "ScaledMoldPart.ipt", oMatrix)
oOcc.Name = "Mold Part"
' Save and close the assembly.
Call oAsmDoc.SaveAs(sFilePath & "MoldSample.iam", False)
oAsmDoc.Close
' Create a new part to derive the assembly into, subtracting the part from the mold base.
' Create a derived definition for the molded assembly.
Dim oDerivedAsmDef As DerivedAssemblyDefinition
Set oDerivedAsmDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sFilePath & "MoldSample.iam")
' Set the part to be subtracted.
oDerivedAsmDef.Occurrences.Item("Mold Part").InclusionOption = kDerivedSubtractAll
' Create the derived assembly.
Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAsmDef)
End Sub
' Sub to create the part representing the molded part.
Private Sub CreateMoldPart(Filename As String)
' Create a new part document using the default part template.
' Create a new sketch on the XY base workplane.
Dim oSketch As PlanarSketch
Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.WorkPlanes(3))
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Draw the geometry defining the shape of the part.
Dim oPoints As ObjectCollection
Set oPoints = ThisApplication.TransientObjects.CreateObjectCollection
oPoints.Add oTG.CreatePoint2d(-5, 0)
oPoints.Add oTG.CreatePoint2d(-4, 3)
oPoints.Add oTG.CreatePoint2d(-2, 4)
oPoints.Add oTG.CreatePoint2d(0, 3)
oPoints.Add oTG.CreatePoint2d(3, 4)
oPoints.Add oTG.CreatePoint2d(4, 2)
oPoints.Add oTG.CreatePoint2d(5, 0)
Dim oSpline As SketchSpline
Set oSpline = oSketch.SketchSplines.Add(oPoints)
oSpline.FitMethod = kSweetSplineFit
Dim oLine As SketchLine
Set oLine = oSketch.SketchLines.AddByTwoPoints(oSpline.FitPoint(1), oSpline.FitPoint(oSpline.FitPointCount))
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create a revolved feature.
Call oPartDoc.ComponentDefinition.Features.RevolveFeatures.AddFull(oProfile, oLine, kJoinOperation)
' Save and close the document.
Call oPartDoc.SaveAs(Filename, False)
oPartDoc.Close
End Sub
' Sub to create the part representing the mold base.
Private Sub CreateMoldBase(Filename As String)
Call oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(-6, -5), oTG.CreatePoint2d(6, 5))
' Create an extruded feature.
Call oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 5, kNegativeExtentDirection, kJoinOperation)
oPartDoc.Close
End Sub
