ilogic form 2012
ilogic form 2012
jletcher
Advisor Advisor
Message 1 of 39
ilogic form 2012
jletcher
Is there a way to get columns in form? I would like to put
Hole F Type { List the types}  Hole F Location {input box}
Hole N Type { List the types}  Hole N Location {input box}
Hole G Type { List the types}  Hole G Location {input box}
If not this form will be off the monitor. Be ten miles long.
Replies (38)
Message 2 of 39
mrattray
Try playing around with the formating controls in the toolbox area. Groups and rows are what your interested in. It will take some practice to learn how to use them. Formating forms in iLogic is oversimplified to the point of being complicated. I'd much rather have a more VBesk form editor.
Mike (not Matt) Rattray
Message 3 of 39
jletcher
Yeah tried all those all they do is put them above or below in a group I would like to have them side by side or my form will be ten miles long.
Message 4 of 39
mrattray
Here's an example of one of my iLogic forms:
I have my options organized into groups and then formated using rows:
Message 5 of 39
jletcher
Dang that looks good well let me play with it more see what I can do the screen shot of your edit form will help..
Message 6 of 39
jletcher
may I ask what code you are using in the generate model?
Message 7 of 39
mrattray
Generate model runs an iLogic rule with over 1400 lines of code. What exactly are you looking for?
Message 8 of 39
jletcher
Yes I did not know those tricks thanks just what I wanted.
Message 9 of 39
jletcher
what I want to do is after the configure the part to do a save as or a save copy as.. This way it keeps the master.
Message 10 of 39
mrattray
Here's a snippet that executes a save as:
Dim fileName As String
Dim path As String
path = "path"
fileName = "fileName"
ThisDoc.Document.SaveAs(path & "\" & fileName & ".idw" , False)
 I use variables inside of the path and fileName variables that allow me to concoct a directory path and part number based file name. Obviously, substitute in the appropriate values for"path", "fileName" and ".idw". Keep the quotes. False does a save as, so it closes the master file and opens the new copy. If you want a save copy as, so the new file does not open, change False to True.
Message 11 of 39
jletcher
Sweet thanks give it a try whe I get back on it should be in day or two.
Message 12 of 39
jletcher
ok figured the saveas part I understand how it works. Question  I want them to be saved in current workspace but rember current workspace will change per job. so is there a code that will make the rule default to current workspace folder when doing saveas?
Message 13 of 39
jletcher
Lol never mind just found it. Works great.
Now I need to find a way it prompts for filename..
Thanks for all your help
Message 14 of 39
mrattray
Look in the snippets, there's an inputbox command.
fileName = InputBox("Please enter a name for your file.", "File Name Input Box", "Default Name")
Message 15 of 39
jletcher
Yeah I got that far but for some reason it is not working but I'm looking like I said new to ilogic but loving it. they need a book on just ilogic.
Dim path As String
path = ThisDoc.WorkspacePath()
ThisDoc.Document.SaveAs(path & "\" & "filename" & ".ipt" , False)
Message 16 of 39
jletcher
got it
Dim path As String
fileName = "filename"
ThisDoc.Document.SaveAs(path & "\" & InputBox("Please enter a name for your file.", "File Name Input Box", "Default Name") & ".ipt" , False)
Message 17 of 39
mrattray
You had some stray quotes where they didn't belong.
Dim path As String
ThisDoc.Document.SaveAs(path & "\" & fileName & ".ipt" , False)
Message 18 of 39
jletcher
I was looking at the sample code for derive. But **** looks as if it is for VBA I looked in snippits but found nothing on ilogic and derive.
I would like to have yes or no to create oppisite hand.
Tried to tale code from sample but I am have no luck.
Do you know a web site or anything I can look at or use snippits?
Message 19 of 39
mrattray
Can you post the sample you're trying to use?
Message 20 of 39
jletcher
Here is the whole code it is to take an assembly and make a mold using derive.
I was taking bits and parts of it to make what I need but I FAIL Smiley Embarassed
Public Sub MoldBaseSample()
    ' Initialize the string that defines the directory where the
    ' files will be created.
    Dim sFilePath As String
    sFilePath = "C:\Temp\"
    ' Call the functions to create the parts that represent the
    ' molded part and the mold base.
    Call CreateMoldPart(sFilePath & "MoldPart.ipt")
    Call CreateMoldBase(sFilePath & "MoldBase.ipt")
    ' Create a new part file to derive the mold part in.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                 ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Create a derived definition for the molded part.
    Dim oDerivedPartDef As DerivedPartUniformScaleDef
    Set oDerivedPartDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(sFilePath & "MoldPart.ipt")
    ' Set the scale to use.
    oDerivedPartDef.ScaleFactor = 1.1
    ' We could set other options for the derived part using the derived part definition.
    ' In this case the defaults are good except for the scale which we changed.
    ' Create the derived part.
    Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
    ' Save and close the part.
    Call oPartDoc.SaveAs(sFilePath & "ScaledMoldPart.ipt", False)
    oPartDoc.Close
    ' Create a new assembly file to put the mold base and scaled part together.
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.Documents.Add(kAssemblyDocumentObject, _
                ThisApplication.FileManager.GetTemplateFile(kAssemblyDocumentObject))
    ' Create the matrix used to define the position of the occurrences.  When a new
    ' matrix is created it is initialized to an identity matrix.  This will cause
    ' parts to be placed into the assembly in the same location that are in part space.
    Dim oMatrix As Matrix
    Set oMatrix = ThisApplication.TransientGeometry.CreateMatrix
    ' Place the mold base.
    Dim oOcc As ComponentOccurrence
    Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "MoldBase.ipt", oMatrix)
    ' Rename the occurrence.  This sample uses the name to identify the occurrence later.
    ' This isn't the only method that could be used, but is one of the simplest.
    oOcc.Name = "Mold Base"
    ' Place the scaled part.
    Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "ScaledMoldPart.ipt", oMatrix)
    oOcc.Name = "Mold Part"
    ' Save and close the assembly.
    Call oAsmDoc.SaveAs(sFilePath & "MoldSample.iam", False)
    oAsmDoc.Close
    ' Create a new part to derive the assembly into, subtracting the part from the mold base.
    ' Create a derived definition for the molded assembly.
    Dim oDerivedAsmDef As DerivedAssemblyDefinition
    Set oDerivedAsmDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sFilePath & "MoldSample.iam")
    ' Set the part to be subtracted.
    oDerivedAsmDef.Occurrences.Item("Mold Part").InclusionOption = kDerivedSubtractAll
    ' Create the derived assembly.
    Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAsmDef)
End Sub
' Sub to create the part representing the molded part.
Private Sub CreateMoldPart(Filename As String)
    ' Create a new part document using the default part template.
    ' Create a new sketch on the XY base workplane.
    Dim oSketch As PlanarSketch
    Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.WorkPlanes(3))
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    ' Draw the geometry defining the shape of the part.
    Dim oPoints As ObjectCollection
    Set oPoints = ThisApplication.TransientObjects.CreateObjectCollection
    oPoints.Add oTG.CreatePoint2d(-5, 0)
    oPoints.Add oTG.CreatePoint2d(-4, 3)
    oPoints.Add oTG.CreatePoint2d(-2, 4)
    oPoints.Add oTG.CreatePoint2d(0, 3)
    oPoints.Add oTG.CreatePoint2d(3, 4)
    oPoints.Add oTG.CreatePoint2d(4, 2)
    oPoints.Add oTG.CreatePoint2d(5, 0)
    Dim oSpline As SketchSpline
    Set oSpline = oSketch.SketchSplines.Add(oPoints)
    oSpline.FitMethod = kSweetSplineFit
    Dim oLine As SketchLine
    Set oLine = oSketch.SketchLines.AddByTwoPoints(oSpline.FitPoint(1), oSpline.FitPoint(oSpline.FitPointCount))
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    ' Create a revolved feature.
    Call oPartDoc.ComponentDefinition.Features.RevolveFeatures.AddFull(oProfile, oLine, kJoinOperation)
    ' Save and close the document.
    Call oPartDoc.SaveAs(Filename, False)
    oPartDoc.Close
End Sub
' Sub to create the part representing the mold base.
Private Sub CreateMoldBase(Filename As String)
    Call oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(-6, -5), oTG.CreatePoint2d(6, 5))
    ' Create an extruded feature.
    Call oPartDoc.ComponentDefinition.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 5, kNegativeExtentDirection, kJoinOperation)
    oPartDoc.Close
End Sub
