Message 1 of 1
Ilogic for PDF export from assembly
04:53 AM
Morning,
I am trying to create some ilogic code for Inventor 2014 that will export PDF's of drawings from the main assembly. Basically I would love to opena top level assembly and have the rule export all the IDW's to PDf's into a folder I specify. The IDW files are not in the same folder as the models but spread out in couple of different places. They also will have to be exported with specific settings (i.e. all lines black and with line weights). Below is the code I have pieced together from other rules that i have found. I am no expert in vb programming so I would be expecially grateful for some assistance. Thank you in advanced.
Sub Main() 'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If 'get user input RUsure = MessageBox.Show ( _ "This will create a PDF file for all of the asembly components that have drawings files." _ & vbLf & "This rule expects that the drawing file shares the same name and location as the component." _ & vbLf & " " _ & vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output PDFs ",MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If PDFSetup Find End Sub Sub PDFSetup() '- - - - - - - - - - - - -PDF setup - - - - - - - - - - - - oPath = ThisDoc.Path PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'get PDF target folder path Find 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - - '- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - - Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'look at the files referenced by the assembly Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments Dim oRefDoc As Document 'work the the drawing files for the referenced models 'this expects that the model has a drawing of the same path and name For Each oRefDoc In oRefDocs idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw" 'check to see that the model has a drawing of the same path and name If(System.IO.File.Exists(idwPathName)) Then Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.Documents.Open(idwPathName, True) oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3) On Error Resume Next ' if PDF exists and is open or read only, resume next 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFileName & "pdf" 'Write out the PDF Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium) 'close the file oDrawDoc.Close Else 'If the model has no drawing of the same path and name - do nothing End If Next '- - - - - - - - - - - - - '- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - - oAsmDrawing = ThisDoc.ChangeExtension(".idw") oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True) oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3) 'write out the PDF for the Top Level Assembly Drawing file On Error Resume Next ' if PDF exists and is open or read only, resume next 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "pdf" 'Write out the PDF Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium) 'Close the top level drawing oAsmDrawingDoc.Close '- - - - - - - - - - - - - MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic") 'open the folder where the new ffiles are saved Shell("explorer.exe " & oFolder,vbNormalFocus) End Sub Sub Find() Function FindFile(RootPath As String, SearchPattern As String) As String Dim di As System.IO.DirectoryInfo = New System.IO.DirectoryInfo(RootPath) Dim files() As System.IO.FileInfo = di.GetFiles(SearchPattern, System.IO.SearchOption.AllDirectories) If files.Length > 0 Then Return files(0).FullName' <-- the 1st found file Else Return Nothing' <-- file not found End If End Function End Sub
