Ilogic for PDF export from assembly
Message 1 of 1
Morning,
I am trying to create some ilogic code for Inventor 2014 that will export PDF's of drawings from the main assembly. Basically I would love to opena top level assembly and have the rule export all the IDW's to PDf's into a folder I specify. The IDW files are not in the same folder as the models but spread out in couple of different places. They also will have to be exported with specific settings  (i.e. all lines black and with line weights). Below is the code I have pieced together from other rules that i have found. I am no expert in vb programming so I would be expecially grateful for some assistance. Thank you in advanced.
Sub Main()
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a PDF file for all of the asembly components that have drawings files." _
& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
& vbLf & " " _
& vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
PDFSetup
Find
End Sub
Sub PDFSetup()
'- - - - - - - - - - - - -PDF setup - - - - - - - - - - - -
oPath = ThisDoc.Path
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'get PDF target folder path
Find
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has a drawing of the same path and name
For Each oRefDoc In oRefDocs
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
'check to see that the model has a drawing of the same path and name
If(System.IO.File.Exists(idwPathName)) Then
		Dim oDrawDoc As DrawingDocument
	oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
	oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3)
	On Error Resume Next ' if PDF exists and is open or read only, resume next
	 'Set the PDF target file name
	oDataMedium.FileName = oFolder & "\" & oFileName & "pdf"
	'Write out the PDF
	Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
	'close the file
	oDrawDoc.Close
Else
'If the model has no drawing of the same path and name - do nothing
End If
Next
'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
oAsmDrawing = ThisDoc.ChangeExtension(".idw")
oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3)
'write out the PDF for the Top Level Assembly Drawing file
oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "pdf"
'Write out the PDF
Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
'Close the top level drawing
oAsmDrawingDoc.Close
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new ffiles are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
End Sub
Sub Find()
Function FindFile(RootPath As String, SearchPattern As String) As String
Dim di As System.IO.DirectoryInfo = New System.IO.DirectoryInfo(RootPath)
Dim files() As System.IO.FileInfo = di.GetFiles(SearchPattern, System.IO.SearchOption.AllDirectories)
If files.Length > 0 Then
Return files(0).FullName' <-- the 1st found file
Else
Return Nothing' <-- file not found
End If
End Function
End Sub
Replies (0)
