iLogic for idw from iam
dan_inv09
Advisor Advisor
Message 1 of 33
dan_inv09
It seems when it gets to this line:
oBaseView = oSheet.DrawingViews.AddBaseView(oAsmCompDef,oPoint,2,kFrontViewOrientation,kHiddenLineRemovedDrawingViewStyle,,,oBaseViewOptions)
it gives this error:
Error in rule: Rule0, in document: DUMMY WELDMENT.iam
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor._Document'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{70109AA1-63C1-11D2-B78B-0060B0EC020B}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Now, let's start off by stating that I have absolutely no idea what I'm doing. I'm just grabbing bits and pieces from other peoples code and trying to reconcile the variables. If someone could just point me in the direction of some sort of syntax so I can figure out what is supposed to be in that statement, that would be great, but I look at it and it all seems like gobbledygook and maybe the error is saying that it is.
I'll attach the whole code if anyone wants to point and laugh. (But if you had some constructive criticism that'd be okay too.)
I've got something misplaced or misspelled or something but I really don't know what it's supposed to look like, so I could really use some help. If anyone can even just tell me where to go to find out what these commands are supposed to look like it would be a big help.
Thank you for taking the time to assist me. I really appreciate it.
Replies (32)
Message 21 of 33
dan_inv09
The views part worked great (with 30 something parts, the view location increment put stuff way off to the side but I can figure out how to get rid of that - I've got to position everything anyway, so there's not problem if they're all right on top of each other).
[Where'd they put the spellcheck button? Ah, that's clever - it's always checking. What are the forums going to be like when everyone is automatically spellchecked? I suppose you can just ignore it, right?]
Message 22 of 33
dan_inv09
Can we put something in here to lock the views to the reps?
I was working with somebody else and they said it involved something like:
' Create a new NameValueMap object
  Dim oBaseViewOptions As NameValueMap
  oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
  ' Set the representations to use when creating the base view.
  oBaseViewOptions.Add("DesignViewAssociative", True)
  ' Create a base view.
  Dim oBaseView As DrawingView
  oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 2, _
                    ViewOrientationTypeEnum.kIsoTopLeftViewOrientation, _
                    DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle,,, _
                    oBaseViewOptions)
but the
is giving me a syntax error
(I kept asking for iLogic and he kept giving me vba and I kept saying I needed it to cycle through a bunch of things and he only gave me code where "Here is where you put THE name of THE view ..." so I think he knew I wouldn't try his vba code. So he gave me code with syntax errors and then had that marked the solution - I think the original poster should be the only one who can declare the issue solved, but I guess I must be wrong.)
Message 23 of 33
It is not necessary to create a name value map to provide the view representation name to the AddBaseView method.
DrawingViews.AddBaseView Method
Parent Object: DrawingViews
Description
Method that creates a new base . The newly created DrawingView is returned.
Syntax
DrawingViews.AddBaseView( Model As Document, Position As Point2d, Scale As Double, ViewOrientation As ViewOrientationTypeEnum, ViewStyle As DrawingViewStyleEnum, [ModelViewName] As String, [ArbitraryCamera] As Variant, [AdditionalOptions] As Variant ) As DrawingView
ModelViewNameOptional input String that defines the design view name for assembly files, or the presentation view name for presentation files. This argument is ignored if the document type specified by the Model argument is a part file (.ipt).
As you can see in the above syntax ModelViewName is an optional argument you can pass in as a string.
 In my previous posts oDesView was the variable name used to pass it in to the Sub routine.
In the Sub routine "viewName" is the variable. Here is a portion of that code.
Dim oDesView As DesignViewRepresentation
    For Each oDesView In oRepMgr.DesignViewRepresentations
        If oDesView.Name <> "Default" And oDesView.Name <> "Master" Then
            Dim oPoint1 As Point2d
            Set oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(ptx, 11)
            Call PlaceBaseView(oSheet, assyDoc, oPoint1, oDesView.Name)
        ptx = ptx + 14
    Next
Public Sub PlaceBaseView(ByRef sheet As Inventor.sheet, _
                        ByRef assyDoc As AssemblyDocument, _
                        ByRef ctrpoint As Point2d, _
                        ByRef viewName As String)
    'define view orientation
    Dim vieworient1 As ViewOrientationTypeEnum
    Let vieworient1 = ViewOrientationTypeEnum.kFrontViewOrientation
    'define view style
    Dim viewstyle1 As DrawingViewStyleEnum
    Let viewstyle1 = DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle
    Dim oFaceView As DrawingView
    Set oFaceView = sheet.DrawingViews.AddBaseView(assyDoc, ctrpoint, 0.5, vieworient1, viewstyle1, viewName)
End Sub
Message 24 of 33
dan_inv09
That's not exactly what I was concerned about.
The main issues I'm having are that:
1. the name value map syntax - oBaseViewOptions.Add("DesignViewAssociative", True) is not right
and whether we do it that way or not
2. I need the drawing view locked to the assembly view rep
I think that what I need is in
What exactly is meant by ArbitraryCamera?
Could that be what I'm looking for?
Do I just put "True" or "Locked" or something there? (Maybe with the quotation marks or something like that?) Or is there some other sort of statement? Or is it something that needs to go into AdditionalOptions somehow? (again, "locked" or perhaps "viewRep=locked" etc.?)
Yesterday I ended up going to the browser and right clicking each view, going to edit view and checking the little "lock" box. Simple enough. Only forty-four times for this drawing.
As I found out in another thread there is no way to automate that after the fact, but surely there must be a way to roll it into creating the view, right?
Message 25 of 33
I believe you can do that by using True with the Associative argument of the SetDesignViewReperenstation Method of the DrawingView object.
Here is the syntax from the programming help;
DrawingView.SetDesignViewRepresentation Method
Description
Method that sets a design view representation for a drawing view of an assembly. This method fails for drawing views of parts and presentations and in the case where the model (assembly) is unresolved.
Syntax
DrawingView.SetDesignViewRepresentation( Representation As String, [Associative] As Boolean )
Parameters
NameDescription
RepresentationString that specifies the Design View Representation to set on the drawing view. The method returns a failure if a representation with this name is not found in the referenced assembly.
AssociativeOptional input Boolean that indicates whether to associatively apply the design view. If set to True, any changes to the design view in the referenced assembly will show in this view. If not specified, a value of False is used.
Message 26 of 33
In my previous post I am referring to an existing View. To achieve this while adding new views you can pass in the associative flag via the AdditionalOptions argument of the AddBaseView Method with a name value map.
Valid values for the NameValue map of the AdditionalOptions argument is shown below:
Name Type Valid Document Type Notes
WeldmentFeatureGroupValue from WeldmentFeatureGroupEnumWeldment
SheetMetalFoldedModelBooleanSheet metal PartDocumentThe part document must contain a flat pattern if a flat view (False) is specified. If a flat doesn't exist, a folded view will be created.
DesignViewRepresentationStringAssemblyThe name of the design view representation.
DesignViewAssociativeBooleanAssemblyIndicates if the drawing view will be associative to the design view. A design view must be specified.
PositionalRepresentationStringAssemblyThe name of the positional representation.
MemberNameStringPart, AssemblyThe name of the iPart or iAssembly member.
PresentationViewStringPresentationThe name of the presentation view.
PresentationViewAssociativeBooleanPresentationIndicates if the view should be associative to the presentation view. A presentation view must be specified
Here is a snippit from the help;
Public Sub AddBaseViewWithRepresentations()
  ' Set a reference to the drawing document.
  ' This assumes a drawing document is active.
  Dim oDrawDoc As DrawingDocument
  Set oDrawDoc = ThisApplication.ActiveDocument
  'Set a reference to the active sheet.
  Dim oSheet As Sheet
  Set oSheet = oDrawDoc.ActiveSheet
  Set oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
  Call oBaseViewOptions.Add("PositionalRepresentation", "MyPositionalRep")
  Call oBaseViewOptions.Add("DesignViewRepresentation", "MyDesignViewRep")
  Call oBaseViewOptions.Add("DesignViewAssociative", True)
  ' Open the model document (corresponding to the "MyLODRep" representation).
  Dim strFullDocumentName As String
  strFullDocumentName = ThisApplication.FileManager.GetFullDocumentName("C:\tempreps.iam", "MyLODRep")
  Dim oModel As Document
  Set oModel = ThisApplication.Documents.Open(strFullDocumentName, False)
  ' Create the placement point object.
  Dim oPoint As Point2d
  Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
  Set oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 2, _
  kIsoTopLeftViewOrientation, kHiddenLineRemovedDrawingViewStyle, _
      , , oBaseViewOptions)
End Sub
Message 27 of 33
dan_inv09
so the syntax problem was the lack of the word Call?
so this should work?
Public Sub CreateViewForEachRep()
    Dim oSheet As sheet
    Dim viewScale As Double
    Let viwScale = 0.1875
    Dim ptx As Long
    Let ptx = 0
    'this assumes that view1 is of the full assembly
    Dim assyDocName As String
    Let assyDocName = oSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.FullDocumentName
    Dim assyDoc As AssemblyDocument
    'open assembly doc invisibly
    Set assyDoc = ThisApplication.Documents.Open(assyDocName, False)
    Dim oAssyCompDef As AssemblyComponentDefinition
    Set oAssyCompDef = assyDoc.ComponentDefinition
    Dim oRepMgr As RepresentationsManager
    Set oRepMgr = oAssyCompDef.RepresentationsManager
        ptx = ptx + 14
    Next
      'close assembly doc
      assyDoc.Close (False)
End Sub
    'define view style
    Set oFaceView = sheet.DrawingViews.AddBaseView(assyDoc, ctrpoint, 0.5, vieworient1, viewstyle1, viewName, , oBaseViewOptions)
End Sub
Message 28 of 33
dan_inv09
That works.
It was just "call" that's been giving me fits for about a month now.
You see, I don't have any sort of a clue about the overall syntax of vba. So, if someone tells me, "'x y z' is the command you need." I will just put 'x y z'. Then when it doesn't work I get frustrated and set it aside and try and move on, when it might just be a case of whoever told me assumed I knew it needed call or set or =something or 'x y z' goes in 'a b c' to make it right.
I need a class or video tutorial or book or something that will help me learn the fundamentals so that I don't make that sort of mistake. For now I still need everything spelled out for me.
Message 29 of 33
xiaodong_liang
Autodesk Support
Autodesk Support
if you are looking for the tutorials of Inventor API, this is the portal that might help you:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1079044
In addition, we have series DevTVs on the modules of Inventor API:
http://adndevblog.typepad.com/manufacturing/2013/05/api-webcast-archive.html
while if what you need is VBA fundamentals, that might turn to MSDN help.
Message 30 of 33
Could this code be tweaked to do the following:
place sheet metal flat patterns (scale 1:1), using ilogic?
I've already found code (ilogic) to open an assembly, apply sheet metal rules & create a flat pattern.
Being able to place these into one dwg for cutting/punching would be a great help.
Andrew
Message 31 of 33
adam.nagy
Autodesk Support
Autodesk Support
Hi Andrew,
Have a look at this:
http://forums.autodesk.com/t5/inventor-customization/ilogic-how-to-place-flat-pattern-on-the-drawing...
The relevant part is:
'False = flat pattern view
oBaseViewOptions.Add("SheetMetalFoldedModel", False)
Adam Nagy
Autodesk Platform Services
Message 32 of 33
Thankyou - I've based my project on this link...(the one you pointed me to)..
I’ve been looking at the code above – I only want the flat pattern & not the three view – I’ve managed to get around this.
I want multiple parts on one drawing.
I have an idea – to save the drawing as a template for part one & reuse that template for part two. However I can’t see where the source document is:
    'Define IDW Template File Location
    'oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Temp\my template.idw", True)
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "", True)
   oSheet = oDrawingDoc.Sheets.Item(1)
Generally sheet metal boxes have several parts which need flattening & nesting into a standard size sheet – I need to provide this geometry.
Having all the parts on one drawing is good.
Message 33 of 33
adam.nagy
Autodesk Support
Autodesk Support
In case of that sample code the source document is the one where you run the iLogic rule:
oPartDoc = ThisDoc.Document
Adam Nagy
