Bend note color adjustment
Hi there,
I am changing dimension and bend note colors to make drawings more clear.
I know that, in SolidWorks, you can change both the 'bend note - up direction' and 'bend note - down direction' colors.
I wish to do that. I want the color of the bend note to be green when it is upwards and red when it is downwards.
Is this at all possible in Inventor?
I managed to make the bend note green as shown in the attachment, but dont know how to seperate up from down.
Edit:
In styles editor I see that in 'Layers' there is a 'Bend centerline +' and 'Bend centerline -'
and in 'Object Defaults' I see only 'Bend Note' and I am unable to create more objects.
Much thanks in regards.
Yijiang.Cai
You are correct! We can't add more objects like "Bend note -Up" and "Bend not - down". So we can't leverage this method to apply different layer for the bend note down/up. But we could leverage the API to get it done.
1. First we create two layers named "Bend Note -Up" and "Bend Note - Down", and assgin the red and green color for these two layers respectively.
2. Please copy the code lines below to make it done. Please also see the attached image.
Sub Test()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oNote As DrawingNote
    For Each oNote In oSheet.DrawingNotes
        If oNote.FormattedText = "<BendNote/>" Then
            If InStr(oNote.Text, "UP") > 0 Then
                oNote.Layer = oDoc.StylesManager.Layers("BendNote-Up")
            Else
                oNote.Layer = oDoc.StylesManager.Layers("BendNote-Down")
    Next
End Sub
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
marcin_otręba
you can change bend line color if you want...
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
I reported you.
Nowhere in the thread I asked for bend line color.
I said bend note color, which can also be changed, but I'm asking for different colors between UP and DOWN.
So great passive agressive comment you got there lad
