Ilogic error - can you help fix?
I am getting an error message with the Ilogic code below. I can't find the fault can you?
ERROR MESAGE...
Error in rule: C3 Drawing EXPORT DWF, in document: Pool Wall.idw
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
MORE INFO...
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Document.Save()
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
ILOGIC CODE...
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 42650 StartFragment: 314 EndFragment: 42618 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'check if custom iproperty "DWF Location" exists and add it if not found
Dim propertyName1 As String = "DWF Location"
customPropertySet = ThisDoc.Document.PropertySets.Item _
("Inventor User Defined Properties")
Try
prop = customPropertySet.Item(propertyName1)
Catch
' Assume error means not found
customPropertySet.Add("Blank", propertyName1)
End Try
'output the custom iproperties and update the file
RuleParametersOutput()
InventorVb.DocumentUpdate()
'Warning - Save current document
question = MessageBox.Show("To proceed you must save this document...          " _
& vbLf & " " _
& vbLf & " " _
& vbLf & " Do you want save and continue?" _, "Warning",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If question = vbNo Then
Return
'Warning - overwrite?
question2 = MessageBox.Show("*** This will overwrite any existing DWF files? ***" _
& vbLf & " " _
& vbLf & " " _
& vbLf & " Do you want to continue?" _, "Warning",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If question2 = vbNo Then
Return
'Is "DWF Location" custom property = "blank"...
If iProperties.Value("Custom", "DWF Location")= "Blank" Then
'Set file location
ODWF_Location = InputBox("File location is not specified. Please enter one." _
& vbLf & " " _
& vbLf & "*** NOTE ***" _
& vbLf & "This location will be saved for next time. It can be altered by changing the IProperty DWF Location, if required" _, "Enter file location", "M:\(A2) Vault duplicate\Designs\Job year 14-15\59 South Edwards Square")
iProperties.Value("Custom", "DWF Location") = ODWF_Location
'UPDATE
iLogicVb.UpdateWhenDone = True
'If message box cancel is selected...
If iProperties.Value("Custom", "DWF Location")="" Then
iProperties.Value("Custom", "DWF Location") = "Blank"
'UPDATE
Return
'save current document
ThisDoc.Save
'Change line weight
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
For Each oLayer In oDrawDoc.StylesManager.Layers
oLayer.LineWeight = 0.001
Next
'this rule outputs all drawing sheets to dwf, 3D models of first sheet included
oLocation = iProperties.Value("Custom", "DWF Location") & "\"
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
DWFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If DWFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("Launch_Viewer") = 0
oOptions.Value("Publish_All_Component_Props") = 1
oOptions.Value("Publish_All_Physical_Props") = 1
oOptions.Value("Password") = 0
oOptions.Value("Publish_3D_Models") = Publish_3D_Models
If TypeOf oDocument Is DrawingDocument Then
Dim oSheets As NameValueMap
oSheets = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Value("Publish_Mode") = DWFPublishModeEnum.kCustomDWFPublish
oOptions.Value("Publish_All_Sheets") = 1
' Publish the first sheet AND its 3D model
Dim oSheet1Options As NameValueMap
oSheet1Options = ThisApplication.TransientObjects.CreateNameValueMap
oSheet1Options.Add("Name", "Sheet:1")
oSheet1Options.Add("3DModel", True)
oSheets.Value("Sheet1") = oSheet1Options
oDataMedium.FileName = oLocation & oFileName & " Rev " & oRevNum & ".dwf"
Call DWFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
ThisApplication.ActiveDocument.Close(True)
Owner2229
Hi, are you running this rule with an event trigger by any chance?
As from the error message the problem seems to be in this:
ThisDoc.Save
You can try to use this instead:
Dim oDoc As Document = ThisApplication.ActiveDocument
oDoc.Save()
Anyway, you can use a message box to determine "how far" your code maid it, e.g.:
' Set document
MsgBox("I've made it to set the active document.")
' Get document type
Dim oType As String = oDoc.DocumentType.ToString
MsgBox("Look what I've found, a document of type: " & oType)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
