iLogic for idw from iam
dan_inv09
Advisor Advisor
dan_inv09
It seems when it gets to this line:
oBaseView = oSheet.DrawingViews.AddBaseView(oAsmCompDef,oPoint,2,kFrontViewOrientation,kHiddenLineRemovedDrawingViewStyle,,,oBaseViewOptions)
it gives this error:
Error in rule: Rule0, in document: DUMMY WELDMENT.iam
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor._Document'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{70109AA1-63C1-11D2-B78B-0060B0EC020B}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Now, let's start off by stating that I have absolutely no idea what I'm doing. I'm just grabbing bits and pieces from other peoples code and trying to reconcile the variables. If someone could just point me in the direction of some sort of syntax so I can figure out what is supposed to be in that statement, that would be great, but I look at it and it all seems like gobbledigook and maybe the error is saying that it is.
I'll attach the whole code if anyone wants to point and laugh. (But if you had some constructive criticism that'd be okay too.)
ADSKDJW4
@dan_inv09,
I will be moving this message to the Inventor Customization Forum as its better suited there for assistance.
Best Regards,
Don
dan_inv09
Don,
Sorry I didn't catch you in time. I should have replied or edited this post when I decided to also try here.
This is the one that started here:
http://forums.autodesk.com/t5/inventor-customization/ilogic-for-idw-from-iam/m-p/6321501#U6321501
JamieVJohnson2
maybe a little late, but the problem is the object your feeding as the "document" is actually an Assembly Component Definition, which is a property of the document, not the document itself.  AssemblyComponentDefinition, is effectively the list of components you see in the browser.  Use oAsmDoc instead of oAsmCompDef.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
