ilogic for excel spreadsheet column sorting
D.Wheeler3GADA
D.Wheeler3GADA
Greetings,
    I am trying to add code to an existing iLogic rule that writes iProperty data to an excel spreadsheeet that will sort all the data in ascending order based on the cell data in column A (all additional row data to follow along) before saving and exiting the document. I am in a huge time crunch and I don't have the opportunity to research for the code myself, which is why I am here asking for help.
In a nutshell: need iLogic code for Excel to sort all rows in ascending order based on the data in column A. (This is a LOG, and would not exceed 100 total rows.
Thank you in advance for any help/tips!
WCrihfield
Hi @D.Wheeler3GADA.  I may be able to help you out there.  I created something for you, but have not tested much yet, but it worked OK on a small sample.  I just threw some of my custom functions in there, because I find them helpful, but you could probably get rid of most, if not all of them, to simplify it later.  The Sub Main area is fairly straight to the point though.  It is opening Excel visibly, because I didn't know which way you needed it, plus its easier to see what happened right away when testing.  Plus, I just leave it open when its done, instead of saving, closing, quitting, but I left some code in there, but commented out, for doing so, if you want.
Here is the iLogic/vb.net code:
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop
Imports Microsoft.Office.Interop.Excel
Sub Main
	Dim oXLFile As String = "C:\Temp\MyExcelFile.xlsx"
	Dim oSheetName As String = "Sheet1"
	Dim oExcel As Excel.Application = GetExcel(True)
	If IsNothing(oExcel) Then Exit Sub
	Dim oWB As Workbook = GetWorkbook(oExcel, False, oXLFile)
	If IsNothing(oWB) Then Exit Sub
	Dim oWS As Worksheet = GetWorksheet(oWB, False, oSheetName)
	If IsNothing(oWS) Then Exit Sub
	Dim oRangeToSort As Range = oWS.UsedRange
	oRangeToSort.Select
'	Dim oLastRowUsed As Integer = oRangeToSort.Rows.Count
'	Dim oLastColumnUsed As Integer = oRangeToSort.Columns.Count
	Dim oKey As Range = oRangeToSort.Range("A1").EntireColumn
	oRangeToSort.Sort(oKey, XlSortOrder.xlAscending, , , , , , _
	XlYesNoGuess.xlNo, , False, XlSortOrientation.xlSortColumns, _
	XlSortMethod.xlStroke, XlSortDataOption.xlSortNormal, _
	XlSortDataOption.xlSortNormal, XlSortDataOption.xlSortNormal)
	'oWS = Nothing
	'oWB.Save
	'oWB.Close
	'oWB = Nothing
	'oExcel.Quit
	'oExcel = Nothing
End Sub
Function GetExcel(Optional oVisible As Boolean = False) As Excel.Application
	Dim oXL As Excel.Application
	Try
		'try to find an already running instance of the Excel Application
		oXL = GetObject(, "Excel.Application")
	Catch
		'it wasn't found open, so create an instance of it (start the application)
		oXL = CreateObject("Excel.Application")
	Catch
		Return Nothing
	End Try
	oXL.Visible = oVisible
	Return oXL
End Function
Function GetWorkbook(oExcelApp As Excel.Application, oNew As Boolean, Optional oTemplateOrFullFileName As String = vbNullString) As Workbook
	If oExcelApp Is Nothing Then Return Nothing
	Dim oFileProvided As Boolean = False
	If oTemplateOrFullFileName <> "" Then oFileProvided = True
	Dim oFileExists As Boolean = False
	If oFileProvided Then oFileExists = System.IO.File.Exists(oTemplateOrFullFileName)
	If oNew = False And oFileExists = False Then Return Nothing
	Dim oWBs As Workbooks = oExcelApp.Workbooks
	Dim oWB As Workbook = Nothing
	If oNew = True AndAlso oFileExists Then
		oWB = oWBs.Add(oTemplateOrFullFileName)
		Return oWB
	ElseIf oNew = True AndAlso oFileExists = False Then
		oWB = oWBs.Add
		Return oWB
	If oWBs.Count > 0 Then
		For Each oWkbk As Workbook In oWBs
			If oWkbk.FullName = oTemplateOrFullFileName Then Return oWkbk
		Next
	ElseIf oWBs.Count = 0 Then
		oWB = oWBs.Open(oTemplateOrFullFileName)
		Return oWB
End Function
Function GetWorksheet(oWorkbook As Workbook, oNew As Boolean, Optional oSheetName As String = vbNullString) As Worksheet
	If oWorkbook Is Nothing Then Return Nothing
	Dim oNameProvided As Boolean = False
	If oSheetName <> "" Then oNameProvided = True
	If oNew = False And oNameProvided = False Then Return Nothing
	Dim oWSs As Excel.Sheets = oWorkbook.Worksheets
	Dim oWS As Worksheet = Nothing
	If oNew Then
		oWS = oWSs.Add(, , 1, XlSheetType.xlWorksheet)
	Else 'oNew was False, so try to find existing
		If oWSs.Count = 0 Then Return Nothing
		Try
			oWS = oWSs.Item(oSheetName)
		Catch
			Return Nothing
		End Try
	If oWS IsNot Nothing Then
		If oNameProvided Then
			If oWS.Name <> oSheetName Then oWS.Name = oSheetName
	Return oWS
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
D.Wheeler3GADA
@WCrihfield
       Thank you for the coding. Wow, I had figured it to be 8-10 lines of code to achieve. That's a novella. I will not have an opportunity to go over that much code until the weekend. I will update you on the progress/result.
Thank you again!
WCrihfield
Hi @D.Wheeler3GADA.  For your information and research, here is a link to that Sort method I am using.  (You may have to change the drop-down on the webpage from C# to VB, in order to see the block of code that way.)  It is definitely a pretty big one, with a lot of possible input variables, but all input variables are 'Optional', and as you can see, I left many of them out, because I did not think they were necessary.  And some I only filled in a value for, because when used multiple times, some of those option/choices are retained in memory, and the only way to use a different option than the last time is to specify it.
The custom Functions are also not really needed, but are convenient tools for varying needs.  As long as you know very specifically what you want to have happen every time, you can avoid using them to shorten the code by transferring a few lines out of them to the Sub Main area.  For instance, if you want to always start a new instance of the Excel application, even if it may already be running; or if you always want to retrieve an already running instance, and never want to create a new session, you can skip the GetExcel function.  When the Excel file already exists, the only slight benefit you might get from the GetWorkbook Function is that it will try to retrieve the already open document, before trying to open it.  And I guess if the named sheet already exists, you don't really get much benefit from the GetSheet function either, so you could fairly easily eliminate that too, by transferring a little code out.  Those were just ready made tools that I had sitting in my 'arsenal', so I included them in the post out of convenience and future aid to you and others.
Wesley Crihfield
mcloughlin_b
Hi Wesley
That's some impressive stuff!
I am needing some assistance with sorting an excel table as follows:
An excel file is created on the fly with the first 2 rows being reserved for headers and the rest being populated across columns "A" to "C" with an inventor assembly occurrence dump ("A" occurrence name, "B" Assembly name, "C" Occurrence total count) . This is easy enough but I would like to sort the created excel sheet on column "A" from a range starting at "A3" and going to the end of column "C?".
I have tried tweaking your code but am stumped with what to put here
	oRangeToSort.Select
 As all my efforts will sort the table from cell "A1" down.
Help \ Ideas are much appreciated.
WCrihfield
Hi @mcloughlin_b.  The 'UsedRange' property of the Excel.Worksheet Interface is pretty sweet.  However, if you only want to be working with the data starting on row 3, and you may not know how many rows there are (or the number of rows varies), then you can you can likely still take advantage of the UsedRange property, like I am doing in Lines 15 & 16 the example above, for finding the last used row, and last used column.  That gives us the location / address of the lower, right cell in the 'used range'.  Then, instead of using the 'used range' itself as the range to sort, you can specify a range that starts with a specified starting cell address ("A3"), to the specified lower, right cell address, for the 'Range' to sort.
oRangeToSort = oWS.Range("A3", "C" & oLastRowUsed.ToString)
Wesley Crihfield
