Hi @D.Wheeler3GADA. I may be able to help you out there. I created something for you, but have not tested much yet, but it worked OK on a small sample. I just threw some of my custom functions in there, because I find them helpful, but you could probably get rid of most, if not all of them, to simplify it later. The Sub Main area is fairly straight to the point though. It is opening Excel visibly, because I didn't know which way you needed it, plus its easier to see what happened right away when testing. Plus, I just leave it open when its done, instead of saving, closing, quitting, but I left some code in there, but commented out, for doing so, if you want.
Here is the iLogic/vb.net code:
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop
Imports Microsoft.Office.Interop.Excel
Sub Main
Dim oXLFile As String = "C:\Temp\MyExcelFile.xlsx"
Dim oSheetName As String = "Sheet1"
Dim oExcel As Excel.Application = GetExcel(True)
If IsNothing(oExcel) Then Exit Sub
Dim oWB As Workbook = GetWorkbook(oExcel, False, oXLFile)
If IsNothing(oWB) Then Exit Sub
Dim oWS As Worksheet = GetWorksheet(oWB, False, oSheetName)
If IsNothing(oWS) Then Exit Sub
Dim oRangeToSort As Range = oWS.UsedRange
oRangeToSort.Select
' Dim oLastRowUsed As Integer = oRangeToSort.Rows.Count
' Dim oLastColumnUsed As Integer = oRangeToSort.Columns.Count
Dim oKey As Range = oRangeToSort.Range("A1").EntireColumn
oRangeToSort.Sort(oKey, XlSortOrder.xlAscending, , , , , , _
XlYesNoGuess.xlNo, , False, XlSortOrientation.xlSortColumns, _
XlSortMethod.xlStroke, XlSortDataOption.xlSortNormal, _
XlSortDataOption.xlSortNormal, XlSortDataOption.xlSortNormal)
'oWS = Nothing
'oWB.Save
'oWB.Close
'oWB = Nothing
'oExcel.Quit
'oExcel = Nothing
End Sub
Function GetExcel(Optional oVisible As Boolean = False) As Excel.Application
Dim oXL As Excel.Application
Try
'try to find an already running instance of the Excel Application
oXL = GetObject(, "Excel.Application")
Catch
'it wasn't found open, so create an instance of it (start the application)
oXL = CreateObject("Excel.Application")
Catch
Return Nothing
End Try
oXL.Visible = oVisible
Return oXL
End Function
Function GetWorkbook(oExcelApp As Excel.Application, oNew As Boolean, Optional oTemplateOrFullFileName As String = vbNullString) As Workbook
If oExcelApp Is Nothing Then Return Nothing
Dim oFileProvided As Boolean = False
If oTemplateOrFullFileName <> "" Then oFileProvided = True
Dim oFileExists As Boolean = False
If oFileProvided Then oFileExists = System.IO.File.Exists(oTemplateOrFullFileName)
If oNew = False And oFileExists = False Then Return Nothing
Dim oWBs As Workbooks = oExcelApp.Workbooks
Dim oWB As Workbook = Nothing
If oNew = True AndAlso oFileExists Then
oWB = oWBs.Add(oTemplateOrFullFileName)
Return oWB
ElseIf oNew = True AndAlso oFileExists = False Then
oWB = oWBs.Add
Return oWB
End If
If oWBs.Count > 0 Then
For Each oWkbk As Workbook In oWBs
If oWkbk.FullName = oTemplateOrFullFileName Then Return oWkbk
Next
ElseIf oWBs.Count = 0 Then
oWB = oWBs.Open(oTemplateOrFullFileName)
Return oWB
End If
End Function
Function GetWorksheet(oWorkbook As Workbook, oNew As Boolean, Optional oSheetName As String = vbNullString) As Worksheet
If oWorkbook Is Nothing Then Return Nothing
Dim oNameProvided As Boolean = False
If oSheetName <> "" Then oNameProvided = True
If oNew = False And oNameProvided = False Then Return Nothing
Dim oWSs As Excel.Sheets = oWorkbook.Worksheets
Dim oWS As Worksheet = Nothing
If oNew Then
oWS = oWSs.Add(, , 1, XlSheetType.xlWorksheet)
Else 'oNew was False, so try to find existing
If oWSs.Count = 0 Then Return Nothing
Try
oWS = oWSs.Item(oSheetName)
Catch
Return Nothing
End Try
End If
If oWS IsNot Nothing Then
If oNameProvided Then
If oWS.Name <> oSheetName Then oWS.Name = oSheetName
End If
End If
Return oWS
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
