It's not actually a function. You launch a command from the API, put it will complete automatically if you set it up with a filename. Here's a function:
Public Sub ExportBottomFaceToDxf(ByVal doc As Document, ByVal app As Inventor.Application)
Dim partDoc As PartDocument = doc
Dim sheetMetalDef As SheetMetalComponentDefinition = partDoc.ComponentDefinition
If (Not sheetMetalDef.HasFlatPattern()) Then
sheetMetalDef.Unfold()
Dim flatPattern As FlatPattern = sheetMetalDef.FlatPattern
flatPattern.Edit()
Dim faceToExport As Face = GetBottomFace(flatPattern)
If (faceToExport Is Nothing) Then
MessageBox.Show("Can't get the bottom face of the flat pattern for the part: " & doc.DisplayName, "Export Flat Pattern as DXF")
Else
partDoc.SelectSet.Select(faceToExport)
Dim filename As String = IO.Path.GetFileNameWithoutExtension(doc.FullFileName) + ".dxf"
app.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, IO.Path.Combine(DxfOutputFolder, filename))
Dim oCtrlDef As ControlDefinition
oCtrlDef = app.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
oCtrlDef.Execute()
flatPattern.ExitEdit()
End Sub
This uses another function GetBottomFace to find the face to be exported.
The PostPrivateEvent call sets up the "GeomToDXFCommand" command with the filename for export. Here I'm using a predefined variable DxfOutputFolder.
Mike Deck
Software Developer
Autodesk, Inc.
