Hi Peter, Ive been 3d modelling for 10+ years however my macro/vb/c++ skills are zero.
I contracted for a company 3 years ago who used solid works (yuk) however a programmer there had created a macro that produced from an assembly file:
1. Individual pages of every part with in the assy
2. Plan orthographic views and a section view... on each page to a scale that suited the page, (as scale rules etc arent as widley used these days, a random scale is sufficient.
Im pretty sure the programing language is similar between Inventor and Solid works, if I sent you that code do you think you could adapt it to be used for Inventor?
Look forward to a response.
Could you please also point me in the right direction for a macro that can: open part from directory, create flat pattern, save, close file, open next file in directory...repeat . I would be very geatfull.
heres a link to the post.
http://forums.autodesk.com/t5/Autodesk-Inventor/Automate-part-placement-on-an-idw-from-an-iam/m-p/27...
Regards, Stefan.
