iLogic Find baloon and zoom contains number Inputbox
dusan.naus.trz
Advisor Advisor
Message 1 of 9
dusan.naus.trz
Hello,  Is something like this possible through iLogic? Does anyone have an idea how to do this?
Running iLogic in a drawing.
myparam = InputBox("Write the number of the position/baloon you are looking for", "Find baloon and zoom contains number Inputbox", "Default Entry")
MessageBox.Show("All sheets contain only =x= occurrences of the searched number of the given balloon." & vbLf & "The active sheet contains =x= searched balloons.", "Title")
'It always starts searching on the active sheet and then continues to other views or other sheets. It switches to the given sheet and zooms in on the balloon number you are looking for.
'If it contains only one baloon of the searched number, then the Msg box will not be displayed. The msg box with the option to continue is displayed only if there are more than one.
MessageBox.Show("Do you want to continue to the next balloon occurrence?", "Title",MessageBoxButtons.YesNo)
Replies (8)
Message 2 of 9
JelteDeJong
try something like this:
Sub Main()
    Dim itemNr As String = InputBox(
			"Find baloon and zoom contains number Inputbox", "")
    Dim doc As DrawingDocument = ThisDoc.Document
    Dim activeSheet As Sheet = doc.ActiveSheet
    If (SearchBaolloon(activeSheet, itemNr)) Then Exit Sub
    For Each sheet As Sheet In doc.Sheets
        If (Sheet Is activeSheet) Then Continue For
    Next
End Sub
Public Function SearchBaolloon(sheet As Sheet, itemNr As String)
    For Each balloon As Balloon In sheet.Balloons
        If (Balloon.BalloonValueSets.Item(1).ItemNumber = itemNr) Then
            Dim p = Balloon.Position
            Dim target = ThisApplication.TransientGeometry.CreatePoint(p.X, p.Y, 0)
            Dim eye = ThisApplication.TransientGeometry.CreatePoint(p.X, p.Y, 100)
            Dim diameter = Balloon.Style.BalloonDiameter
            ' looking at a full size baloon is no fun. Therefore we zoom out a bit
            diameter = diameter * 7.5
            Dim camera As Camera = ThisApplication.ActiveView.Camera
            camera.Target = target
            camera.Eye = eye
            camera.SetExtents(diameter, diameter)
            camera.Apply()
            Dim result = MessageBox.Show(
				"Title", MessageBoxButtons.YesNo)
            If (result = DialogResult.No) Then
                Return True
    Next
    Return False
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 9
dusan.naus.trz
@JelteDeJong
Thank you very much. This is incredible. It's amazing. I didn't think such a thing was possible.
Message 4 of 9
dusan.naus.trz
@JelteDeJong
According to the picture. I tried to find Baloon/Item 3 and nothing happened. Is there a trick to it?
Message 5 of 9
JelteDeJong
I did not think of testing the attached balloons. But with a small adjustment, I can solve that. Have a look at his code:
Sub Main()
    Next
End Sub
        For Each valueSet As BalloonValueSet In Balloon.BalloonValueSets
            If (valueSet.ItemNumber = itemNr) Then
                ZoomToBalloon(Balloon)
                    Return True
        Next
    Next
    Return False
End Function
Public Sub ZoomToBalloon(balloon As Balloon)
    Dim p = balloon.Position
    Dim diameter = balloon.Style.BalloonDiameter
    camera.Eye = eye
    camera.Apply()
End Sub
Jelte de Jong
Message 6 of 9
dusan.naus.trz
@JelteDeJong
Thank you very much for your patience. It's perfect.
Message 7 of 9
Jesper_S
Hi.
Really nice piece of iLogic, will come to good use.
I got a code to locate on what view and sheet a balloon is located.
Only thing is that it won't locate balloons that are in a group.
You perhaps got a fix for that?
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
Dim oBalloon As Balloon
Dim oBalloonValueSet As BalloonValueSet
Dim oSheet As Sheet
For Each oSheet In oDrawDoc.Sheets
	If oMesssage = "" Then
		oMesssage = oSheet.Name
	Else
		oMesssage = oMesssage & vbLf & oSheet.Name
	oSheet.Activate
	For Each oBalloon In oDrawDoc.ActiveSheet.Balloons
		oViewName = oBalloon.ParentView.Name
		oItem = oBalloon.BalloonValueSets.Item(1).Value
		oMesssage = oMesssage & vbLf & "Balloon # " & oItem & " is on " & oViewName
	Next
	oMesssage = oMesssage & vbLf & "___________________"
Next
oActiveSheet.Activate 'return to original sheet
MessageBox.Show(oMesssage, "iLogic")
//Jesper
Message 8 of 9
dusan.naus.trz
@Jesper_S
I modified the code a bit.
Do you mean something like that?
Class ThisRule
	Dim moje As Integer = 1
	Sub main
		'	MessageBox.Show("zacatek" & moje, "Title")
		'		Dim itemNr As String = InputBox(
		'		"Write the number of the position/baloon you are looking for",
		'		"Find baloon and zoom contains number Inputbox", "")
		"CZ = Napište číslo pozice, které hledáte" & vbLf & "EN = Write the position number you are looking for", "Umístění Pozice na všech listech/Show location Baloon in All Sheets")
		If itemNr = "" Then
			MessageBox.Show("CZ = Příkaz ukončen" & vbLf & "EN = The command ended.", "Ukončení příkazu")
			Return 'exit rule
		Dim oSheet As Sheet
			oSheet.Activate
			'		MessageBox.Show("pp" & moje, "Title")
			If moje = 2 Then
				Exit For
				Exit Sub
			Else
				'			MessageBox.Show("funkce" & moje, "Title")
				SearchBaolloon(oSheet, itemNr)
			If moje = 2 Then Exit For
		Next
		If moje = 2 Then Exit Sub
	End Sub
	Public Sub SearchBaolloon(sheet As Sheet, itemNr As String)
		'	For Each balloon As Balloon In Sheet.Balloons
		'		If (Balloon.BalloonValueSets.Item(1).ItemNumber = itemNr) Then
					camera.Eye = eye
					camera.Apply()
					"CZ = Chcete pokračovat k dalšímu výskytu pozice?" & vbLf & "EN = Do you want to continue to the next balloon occurrence?",
					"Pokračuj na další pozici/Continue next Baloon", MessageBoxButtons.YesNo)
						moje = 2
'						MessageBox.Show("Ne" & moje, "Title")
						Exit For
						Exit Sub
					Else
						moje = 1
			Next
			'	If moje = 2 Then Exit Sub'Function
			'    Return Nothing'Return False
		Next
	End Sub
End Class
Message 9 of 9
Jesper_S
Hi.
No.
Want the ballons that are connected to the first ballonon the view to show up in the list as well.
Now, it only shows the first ballon, in the case above, item 19, 22 & 22 (Again) in View B, but the other ballons don't show up.
//Jesper
