Automatic Drawing View Label Doesnt Work If View Is At an Angle
C_Haines_ENG
C_Haines_ENG
I currently have this code to automatically name drawing views, however this only works if the viewcube is in the exact orientation with no rotation.
'[ SETUP BLOCK
Dim tmpSheet As Sheet = ThisDrawing.ActiveSheet.Sheet 'Set active sheet for local iLogic rule existing inside Drawing document
Dim oView As DrawingView = tmpSheet.DrawingViews.Item(1) 'Get 1st view to determin base output
Dim oRDD As DocumentDescriptor = oView.ReferencedDocumentDescriptor
Dim oModelType As String
'[ VIEW LOOP
For Each tmpView As DrawingView In tmpSheet.DrawingViews
	Dim myDrawingViewName As String = ""
	'Check name. anything NOT matching the master list or the name is NOT numbers only will get skipped
	If Not masterList.Contains(tmpView.Name) And Not IsNumeric(tmpView.Name) Then Continue For
	Dim oTrans As Transaction
	oTrans = ThisApplication.TransactionManager.StartTransaction(ThisDrawing.Document, "Rotate Drawing View temp")
		' Set rotation to 0
	If tmpView.Camera.ViewOrientationType = ViewOrientationTypeEnum.kArbitraryViewOrientation Then
		If tmpView.Rotation <> 0 Then
			tmpView.Rotation = 0
'[ CASE SELECTOR
'[ PART VIEW LABELS
    Select Case tmpView.Camera.ViewOrientationType
        Case ViewOrientationTypeEnum.kBackViewOrientation
            myDrawingViewName = "O/S FACE"
        Case ViewOrientationTypeEnum.kBottomViewOrientation
            myDrawingViewName = "BOTTOM"
        Case ViewOrientationTypeEnum.kFrontViewOrientation
            myDrawingViewName = "I/S FACE"
        Case ViewOrientationTypeEnum.kIsoBottomLeftViewOrientation
            myDrawingViewName = ""
        Case ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
        Case ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
        Case ViewOrientationTypeEnum.kIsoTopRightViewOrientation
        Case ViewOrientationTypeEnum.kLeftViewOrientation
            myDrawingViewName = "END"
        Case ViewOrientationTypeEnum.kRightViewOrientation
        Case ViewOrientationTypeEnum.kTopViewOrientation
            myDrawingViewName = "TOP"
        Case Else
    End Select
    If Not myDrawingViewName = "" Then
        tmpView.Name = myDrawingViewName
'Always close your Transactions
oTrans.End
Next
 I cant find the original post where this code was given, however the addition near the top of
		' Set rotation to 0
Was supposed to resolve the problem. It did not.
Does anyone know how to fix this bug? Ive checked what I can and the view sends back that its at 0 degrees no matter what so I guess that didnt fix it at all.
Ive decided to add more context here. If a drawing view is orented like this:
It works fine. However if the view is oriented as such:
It doesnt work, I understand this is because ViewOrientationTypeEnum.kTopViewOrientation is technically not true due to this however that is remarkably dumb....
dalton98
Use pi / 2 instead of 0. Then change it back after you set the name.
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oView As DrawingView = oDDoc.ActiveSheet.DrawingViews(1)
MessageBox.Show(oView.Camera.ViewOrientationType.ToString)
origionalRotation = oView.Rotation
oView.Rotation = PI / 2
myDrawingViewName = oView.Camera.ViewOrientationType.ToString
oView.Rotation = origionalRotation
MessageBox.Show(myDrawingViewName)
C_Haines_ENG
This sadly doesnt work, It stays as an "arbitrary view"
dalton98
Can you post ur code? It works for me.
C_Haines_ENG
'[ SETUP BLOCK
'Set list for names you want to identify. Anything matching these names will be updated
Dim masterList As New List(Of String)
masterList.AddRange({"BACK", "BOTTOM", "FRONT", "SIDE", "TOP", "O/S FACE", "I/S FACE", "END"})
'[ VIEW LOOP
		' Set rotation to 0
		origionalRotation = tmpView.Rotation
			tmpView.Rotation = PI / 2
'[ CASE SELECTOR
	'[ PART VIEW LABELS
If Parameter("DrawingType") <> "Part"
            myDrawingViewName = "BACK"
            myDrawingViewName = "FRONT"
            myDrawingViewName = "ISOMETRIC"
            myDrawingViewName = "SIDE"
        Case Else
    End Select
'[ PART VIEW LABELS
Else
        Case Else
			MessageBox.Show(tmpView.Rotation, "Title")
    End Select
tmpView.Rotation = origionalRotation
oTrans.End
Next
dalton98
Ohh ok this is odd. The view.Rotation (original rotation) seems to always be 0. Not the true rotation based off the cube. I got it to work by running the rule twice. 1st time setting the rotation = pi / 2. 2nd time setting the rotation = pi. Depending on the way the view was originally rotated.
It can be setup something like this:
	Case Else
End Select
	Case Else
		'nothing
End Select
 Also on line 61 you are setting the value back to " ".
dalton98
I wrote this. It uses a function to determine the drawingViewName. It makes it cleaner imo.
Sub Main
	'[ SETUP BLOCK
	masterList.AddRange({"BACK", "BOTTOM", "FRONT", "SIDE", "TOP", "O/S FACE", "I/S FACE", "END" })
	'[ VIEW LOOP
		'	If Not masterList.Contains(tmpView.Name) Then Continue For
		'	Dim oTrans As Transaction
		'	oTrans = ThisApplication.TransactionManager.StartTransaction(ThisDrawing.Document, "Rotate Drawing View temp")
		If tmpView.Camera.ViewOrientationType <> ViewOrientationTypeEnum.kArbitraryViewOrientation Then
			myDrawingViewName = NotPartViewLabels(tmpView)
		Else
			If myDrawingViewName = ""
	Next
End Sub
Function NotPartViewLabels(tmpView As DrawingView)
	'[ PART VIEW LABELS
        Case Else
    End Select
Return myDrawingViewName
End Function
