iLogic. Find all planes in file and add them to collection.
a9011
a9011
Greetings to all forum participants.
Can you help write the code for the rule? I need to find all planes in the file, add them to the list. After that, it is necessary to find a closed contour in each plane and apply the extrusion operation to it.
Thank you for your attention to my question!
Дорогу спроектирует идущий!
bhavik4244
@a9011
To set the array for Workplanes here below is the code, to get the extrude feature for the close profiles you may find something from below this link: http://inventortrenches.blogspot.com/2012/03/ilogic-to-select-all-of-closed-profiles.html
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim WPArray As New ArrayList
For Each oWorkPlane In ThisDoc.Document.ComponentDefinition.WorkPlanes
If oWorkPlane.IsCoordinateSystemElement = False Then
WPArray.Add(oWorkPlane.Name)
End If
MessageBox.Show(oWorkPlane.Name, "Title")
Next
Bhavik Suthar
a9011
Thank You! It works for me!
