iLogic Extract Material Physical Properties
b.mccarthy
Message 1 of 10
b.mccarthy
Hello.
Is it possible to extract a material's physical properties using iLogic? I.e.  Poisson's Ratio, Density, Yield Strength, etc.
Thank you.
Replies (9)
Message 2 of 10
TomaszDąbrowski
Dim oDoc As PartDocument = ThisDoc.Document
Dim MatName As String = oDoc.ComponentDefinition.Material.Name
Dim PR As Double = oDoc.ComponentDefinition.Material.PoissonsRatio
Dim Den As Double = oDoc.ComponentDefinition.Material.Density
Dim YS As Double = oDoc.ComponentDefinition.Material.YieldStrength
MsgBox("Material " & MatName & " has Poisson's Ratio: " & PR & ", Density: " & Den & ", Yield Strength: " & YS)
Message 3 of 10
b.mccarthy
Perfect!
Thank you!!
Message 4 of 10
b.mccarthy
I noticed that there is discontinuity between the Inventor material database, and the values the code presents:
Inventor Material Specs for Mild Steel:
Values reported by iLogic Code:
The Material and Poisson's Ratio are good, but the Density and Yield Strength do not match. Why are the values so different, and what tweaks need to be made to the code to display the data correctly?
Thank you.
Message 5 of 10
TomaszDąbrowski
That is because the units are different.
Yield strength is given in MPa (mega Pascal)
Density is given in g/cm3 (gram per cubic centimeter)
Message 6 of 10
b.mccarthy
Ok. Can you add code that will convert the values prior to displaying the dialog?
TIA
Message 7 of 10
TomaszDąbrowski
ok
Dim DenMetric As Double = oDoc.ComponentDefinition.Material.Density
Dim DenImperial As Double = DenMetric*0.03613
Dim YSMetric As Double = oDoc.ComponentDefinition.Material.YieldStrength
Dim YSImperial As Double = YSMetric * 145.04
MsgBox("Material " & MatName & " has Poisson's Ratio: " & PR & ", Density: " & DenImperial & " [lb/in3], Yield Strength: " & YSImperial & " [psi].")
Message 8 of 10
b.mccarthy
Thank you.
So iLogic does not contain a conversion expression?
Message 9 of 10
TomaszDąbrowski
I was surprised to find out that there is such converter:
Dim DenImperial As Double = oDoc.UnitsOfMeasure.ConvertUnits(DenMetric,"g/(cm cm cm)","lb/(in in in)")
Dim YSImperial As Double = oDoc.UnitsOfMeasure.ConvertUnits(YSMetric, "MPa", "psi")
Message 10 of 10
b.mccarthy
Excellent!
Thank you.
