ilogic export step to custom directory
Hi Guys,
We've got a few Ilogic external rules we use regularly to export PDF/DXF's of our sheet metal parts for laser cutting and folding. They go into a specific directory on another drive for our purchasing staff to use.
Our suppliers have a new software which can work more efficiently using .step files. I found a code which exports the step file to the same directory the parts our saved, but I'm not great with ilogic and I'm struggling to figure out how to direct the exported part to the specific directory we want them to go to.
This is the step file code, I've seen it posted in a few different threads.
' Start of iLogic code *******************************************
Stepfilename = ThisDoc.PathAndFileName(False)
FileExists = True
'check to see if the file to be exported already exists
Do While FileExists
    ' Define name of exported file - note a .stp file extension
    ' Is currently being used. In this example I am exporting a Step file
	Rev = iProperties.Value("Project", "Revision Number")
    CurrentFile = Stepfilename & Rev & ".stp"
    'If Dir(CurrentFile) <> "" Then ' The file does exist
     '   Counter += 1
      '  FileExists = True
    'Else
        SaveAs = MessageBox.Show("Export file as '" & CurrentFile & _
        "'?", "Cadline iLogic", _
        MessageBoxButtons.YesNo, MessageBoxIcon.Question, _
        MessageBoxDefaultButton.Button1)
        If SaveAs = vbNo Then
            Return
        Else ' User says continue
            FileExists = False
        End If
 '   End If
Loop
' Put your export or 'save as' code in here ***********************
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById _
("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument _
, oContext, oOptions) Then
    oOptions.Value("ApplicationProtocolType") = 3
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    ' Set export name of STEP file
    oData.FileName = CurrentFile
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext _
, oOptions, oData)
End If
' End of export code ***********************************************
' Ask user if they want to open the export folder
'OpenFolder = MessageBox.Show("Export successful! " & _
'"- open containing folder now?", "Cadline iLogic", _
'MessageBoxButtons.YesNo, _
'MessageBoxIcon.Question,MessageBoxDefaultButton.Button1)
'If OpenFolder = vbYes Then
'    Process.Start("explorer.exe", ThisDoc.Path)
'Else ' User says continue
    'Return
'End If
' End of iLogic code **************************************************
I've looked at these snippets of our dxf export code to try and get the parts directing the file to the correct directory
Dim sPATH As String
    sPATH = "P:\Procurement\Drawing"
    sOut = "FLAT PATTERN DXF?AcadVersion=2000&OuterProfileLayer=IV_INTERIOR_PROFILES"
    Dim sFname As String
    sFname = sPATH & "\" & ThisDoc.FileName(False) & iProperties.Value("Project", "Revision Number") & ".dxf"
    MessageBox.Show("DXF SAVED TO: " & sFname ,"DXF Saved", MessageBoxButtons.OK)
Any help would be greatly appreciated
Matt
mcgyvr
Change this line..
To this..
CurrentFile = "C:\Mylocation\" & Stepfilename & Rev & ".stp"
C:\Mylocation\ is the folder path where you want it saved..
Easy as that, thanks
