iLogic export flat pattern to dxf and add some text
b.graaf
b.graaf
I have made some iLogic code to export flat patterns to a dxf file. I have used this peace of code: _dataIO.WriteDataToFile(......) Is it possible to add some text to this dxf file?
lmc.engineering
Hi @b.graaf,
As far as I am aware, this is not possible in Inventor as standard.
There is however the option of an add-in, try this here: Sheet Metal DXF Exporter
Personally, I ended up creating a VBA Macro in Inventor that writes script for AutoCAD to deal with post processing of dxf's and dwg's. Mainly because nothing out there suited my needs, and because I could 😉
chandra.shekar.g
Autodesk Support
Autodesk Support
@b.graaf,
Unfortunately, Inventor API does not support directly to export dxf along with text. Please log this wish list at idea station using below link.
Sheet Metal DXF Exporter - May be using AutoCAD API as well to include text into dxf file.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
