ilogic: Export component iproperties to excel
i want to export iproperties of components of an iam to an excel file.
I have found a ilogic code for this and it works fine.
I have changed the iproperties to mass and it exports but the the mass propertie losts it Units:
Maybe someone could help me.
This is the Result of the Mass-property i get:
Part NumberDateMass
3307030a_00328.07.2016 10:33:03232.673.618.367.318
3307030a_00228.07.2016 10:31:027.084.782
100102504.07.2016 10:05:1514.956.997.139.373
1001025_00304.07.2016 10:03:45113.825
1001025_00104.07.2016 09:58:26497.297.139.372.957
1001025_00204.07.2016 10:02:2014004,4
DIN 1025 - IPBl 450-639920.03.2015 07:19:1589.427.186.291.118
This is the result i want:
Masse
894,272 kg
7,085 kg
2,327 kg
14,957 kg
This is my code:
GoExcel.Open("c:\Temp\AAA\EXPORT1.xlsx", "Tabelle1")
'Print column titles in the row 2
Dim Names={"Display name", "Title", "Part Number", "Date", "Material"}
GoExcel.CellValues("A2", "E2") = Names
Dim oAsmDoc As AssemblyDocument = TryCast(ThisApplication.ActiveDocument,AssemblyDocument)
If oAsmDoc Is Nothing Then
    MessageBox.Show("Activate assembly document first", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Information)
    Exit Sub
End If
Dim Data(4) As String    'string array for properties
Dim row As Integer = 3    'start data row
Dim oPropSet As PropertySet
Dim oProp As Inventor.Property
For Each oDoc As Inventor.Document In oAsmDoc.AllReferencedDocuments
    'full filename
    Data(0) = oDoc.FullFileName
    'Title
    oPropSet = oDoc.PropertySets.Item("Inventor Summary Information")
    oProp = oPropSet.Item("Title")
    Data(1) = oProp.Value
    'Part Number
    oPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
    oProp = oPropSet.Item("Part Number")
    Data(2) = oProp.Value
    'Date
    oProp = oPropSet.Item("Creation Time")
    Data(3) = oProp.Value
    'Revision
    oProp = oPropSet.Item("Mass")
    Data(4) = oProp.Value
    'Masse
'    mass = iProperties.Mass
'    MessageBox.Show(mass, "Title")
'    Data(4) = mass
    GoExcel.CellValues("A" & CStr(row), "E" & CStr(row)) = Data
    row += 1
Next
GoExcel.Save
GoExcel.Close
MessageBox.Show("Done", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Information)
' === end of the rule ===
Maybe someone have a solution for me,
thanks Richi
Owner2229
Hey, instead of:
oProp.Value
use:
oProp.Expression
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thank you for your answere, but i get the same result 😉
Part NumberDateMasse
3307030a_00328.07.2016 10:33:032.326.736.184
100102504.07.2016 10:05:150,
DIN 1025 - IPBl 450-639920.03.2015 07:19:15894.271.862.911
S_May
Two tools for exporting iProperties to Excel.
Extension = EXE
greetingsSmiley Happy
Sascha
Owner2229
Hey, it looks like you can't get the units from the iProperty directly, but you can get them from the document:
 'Revision
    Dim UOM As UnitsOfMeasure = oDoc.UnitsOfMeasure
    Dim oMU As UnitsTypeEnum = UOM.MassUnits
    Dim oUnit As String = UOM.GetStringFromType(oMU)
    Data(4) = UOM.GetStringFromValue(oProp.Expression, oMU)
Mike
