iLogic: Export All Flat Patterns To One DXF (Mirrored Parts can't display at Flat Patterns)
Jhoel Forshav solved the problem with his rule, but i have a little problem. in my assambly lots of different sheet metals. when i run the rules sheets comes with only part number/name and scale. in addition i must see thickness and quantity. how can i do it? in code where will be changed? actually other solution is participating sheet metals for thickness is excellant (i know it can be more difficult) here is the rule. (SOLVED)
In the other hand when i test it, another problem noticed.
Mirrored parts doesn't goes to flat patterns. Can anyone help me?
Sub Main 'iLogic Code by Jhoel Forshav - originally posted at https://clintbrown.co.uk/ilogic-export-all-flat-patterns-to-one-dxf 'Check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule can only run from an Assembly file", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Error) Exit Sub End If 'Dim the active document as AssemblyDocument Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument 'Make sure the assembly is saved If oDoc.FullFileName = "" MessageBox.Show("Please save the Assembly before running this rule.", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Information) Exit Sub End If 'Get the assembly filename without extension Dim oAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) 'Get the assembly filepath Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName) 'Get the parts only BOM. Dim oBOM As BOM = oDoc.ComponentDefinition.BOM 'Make sure Parts Only is activated oBOM.PartsOnlyViewEnabled = True 'Parts only will be last BomView (difficult to get by name since it's different depending on your language) Dim oBOMview As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count) 'Set a reference to the TransientGeometry object Dim oTG As TransientGeometry = ThisApplication.TransientGeometry 'oX and oY will be used to create points for view placement Dim oX As Double = 0 Dim oY As Double = 0 'Create the Baseview options to place flatpattern-views Dim oBaseViewOptions As NameValueMap oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap oBaseViewOptions.Add("SheetMetalFoldedModel", False) 'Set a variable for the drawing document Dim oDrawing As DrawingDocument 'Create a String to return a message if any SM-parts are not saved Dim unsavedSmParts As String = "" Dim i As Integer = 1 Dim oInfo As String = "" 'Traverse Parts Only BOM For Each oRow As BOMRow In oBOMview.BOMRows Try 'Get the component definition for the part Dim oDef As ComponentDefinition = oRow.ComponentDefinitions(1) 'Check if the part is SheetMetal If TypeOf (oDef) Is SheetMetalComponentDefinition 'Set a reference to the partdocument Dim smPartDoc As PartDocument = oDef.Document 'Check if the part is saved If smPartDoc.FullFileName = "" Then If unsavedSmParts = "" Then unsavedSmParts = "The fallowing SM-documents were not saved and therefore " & _ "no drawingviews were created:" & vbCrLf unsavedSmParts = unsavedSmParts & vbCrLf & oDef.Document.DisplayName Continue For End If 'Create flatpattern if it doesn't already exist If Not oDef.HasFlatPattern oDef.Unfold() oDef.FlatPattern.ExitEdit() End If 'Create the drawing if it doesn't already exist If oDrawing Is Nothing oDrawing = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, _ , False) 'Set the drawings length units to the same as the assemblys length units oDrawing.UnitsOfMeasure.LengthUnits = oDoc.UnitsOfMeasure.LengthUnits End If 'Set a reference to the drawing sheet Dim oSheet As Sheet = oDrawing.ActiveSheet 'Create the flatpattern view Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(smPartDoc, oTG.CreatePoint2d(oX, oY), 1 _ , ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, _ "FlatPattern", , oBaseViewOptions) oView.Name = smPartDoc.DisplayName oView.ShowLabel = True 'Set the position with our oX and oY oView.Position = oTG.CreatePoint2d(oView.Position.X + oView.Width / 2, oView.Position.Y) 'Move oX to place the next view to the right of this one oX = oView.Left + oView.Width + 1 'Remove the bend lines of the view RemoveBendLines(oView, oDef.FlatPattern)'You could comment out this line to keep bend lines oInfo = oInfo & If (i = 1, "", vbCrLf) & i & ". " & smPartDoc.PropertySets.Item("Design Tracking Properties"). _ Item("Part Number").Value i += 1 'Close the part smPartDoc.Close(True) End If Catch Ex As Exception MsgBox(Ex.Message) End Try Next If oDrawing IsNot Nothing 'Create the save location string for the DXF Dim oDXFName As String = oPath & "\" & oAsmName & "_FlatPatterns.dxf" 'Save the DXF oINI = "" 'Specify your INI file location here (eg C:\TEMP\DXF Export.ini) If oINI = "" Then MessageBox.Show("You need to specify an INI file location in the code - Look for oINI and set the path", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error) End If SaveDXF(oDrawing, oDXFName, oINI) 'Create the save location string for the information txt Dim oInfoName As String = oPath & "\" & oAsmName & "_FlatPatterns.txt" 'Create the txt CreateTXT(oInfo, oInfoName) End If 'Close the drawing oDrawing.Close 'return information about any unsaved parts If unsavedSmParts <> "" Then _ MessageBox.Show(unsavedSmParts, "Some parts were not saved", _ MessageBoxButtons.OK, MessageBoxIcon.Information) 'Update the assembly (could be dirty if any flatpatterns were created) oDoc.Update End Sub Sub SaveDXF(oDrawing As DrawingDocument, oFileName As String, oIniFile As String) 'Set a reference to the DFX translator Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Create translation context Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism 'Create options for the translation Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap 'Create a DataMedium object Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium 'Set the options (which .ini-file to use) If DXFAddIn.HasSaveCopyAsOptions(oDrawing, oContext, oOptions) Then oOptions.Value("Export_Acad_IniFile") = oIniFile End If 'Set the filename property of the DataMedium object oDataMedium.FileName = oFileName Try 'Try to save the DXF DXFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium) MessageBox.Show("Dxf saved to: " & oFileName, "DXF SAVED", MessageBoxButtons.OK, MessageBoxIcon.Information) Catch MessageBox.Show("Couldn't save dxf!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error) End Try End Sub Sub RemoveBendLines(oView As DrawingView, oFlattPattern As FlatPattern) 'Get all the bend edges from the FlatPattern Dim oBendEdgesUp As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge) Dim oBendEdgesDown As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge) For Each oEdge As Edge In oBendEdgesUp 'Get the curves representing these edges in the drawing view For Each oCurve As DrawingCurve In oView.DrawingCurves(oEdge) For Each oSegment As DrawingCurveSegment In oCurve.Segments 'Set visibility to false oSegment.Visible = False Next Next Next For Each oEdge As Edge In oBendEdgesDown For Each oCurve As DrawingCurve In oView.DrawingCurves(oEdge) For Each oSegment As DrawingCurveSegment In oCurve.Segments oSegment.Visible = False Next Next Next End Sub Sub CreateTXT(oText As String, oFileName As String) Dim oTxtWriter As System.IO.StreamWriter = System.IO.File.CreateText(oFileName) oTxtWriter.WriteLine(oText) oTxtWriter.Close() End Sub
