iLogic: Export All Flat Patterns To One DXF (Mirrored Parts can't display at Flat Patterns)
ali_akay
ali_akay
Jhoel Forshav solved the problem with his rule, but i have a little problem. in my assambly lots of different sheet metals. when i run the rules sheets comes with only part number/name and scale. in addition i must see thickness and quantity. how can i do it? in code where will be changed? actually other solution is participating sheet metals for thickness is excellant (i know it can be more difficult) here is the rule. (SOLVED)
In the other hand when i test it, another problem noticed.
Mirrored parts doesn't goes to flat patterns. Can anyone help me?
Sub Main
	'iLogic Code by Jhoel Forshav - originally posted at https://clintbrown.co.uk/ilogic-export-all-flat-patterns-to-one-dxf
	'Check that the active document is an assembly file
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("This rule can only run from an Assembly file", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Error)
		Exit Sub
	End If
	'Dim the active document as AssemblyDocument
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	'Make sure the assembly is saved
	If oDoc.FullFileName = ""
		MessageBox.Show("Please save the Assembly before running this rule.", "DXF-creator", MessageBoxButtons.OK, MessageBoxIcon.Information)
		Exit Sub
	End If
	'Get the assembly filename without extension
	Dim oAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
	'Get the assembly filepath
	Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName)
	'Get the parts only BOM.
	Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
	'Make sure Parts Only is activated
	oBOM.PartsOnlyViewEnabled = True
	'Parts only will be last BomView (difficult to get by name since it's different depending on your language)
	Dim oBOMview As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count)
	'Set a reference to the TransientGeometry object
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	'oX and oY will be used to create points for view placement
	Dim oX As Double = 0
	Dim oY As Double = 0
	'Create the Baseview options to place flatpattern-views
	Dim oBaseViewOptions As NameValueMap
	oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oBaseViewOptions.Add("SheetMetalFoldedModel", False)
	'Set a variable for the drawing document
	Dim oDrawing As DrawingDocument
	'Create a String to return a message if any SM-parts are not saved
	Dim unsavedSmParts As String = ""
	Dim i As Integer = 1
	Dim oInfo As String = ""
	'Traverse Parts Only BOM
	For Each oRow As BOMRow In oBOMview.BOMRows
		Try
			'Get the component definition for the part
			Dim oDef As ComponentDefinition = oRow.ComponentDefinitions(1)
			'Check if the part is SheetMetal
			If TypeOf (oDef) Is SheetMetalComponentDefinition
				'Set a reference to the partdocument
				Dim smPartDoc As PartDocument = oDef.Document
				'Check if the part is saved
				If smPartDoc.FullFileName = "" Then
					If unsavedSmParts = "" Then unsavedSmParts = "The fallowing SM-documents were not saved and therefore " & _
					"no drawingviews were created:" & vbCrLf
					unsavedSmParts = unsavedSmParts & vbCrLf & oDef.Document.DisplayName
					Continue For
				End If
				'Create flatpattern if it doesn't already exist
				If Not oDef.HasFlatPattern
					oDef.Unfold()
					oDef.FlatPattern.ExitEdit()
				End If
				'Create the drawing if it doesn't already exist
				If oDrawing Is Nothing
					oDrawing = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, _
					, False)
					'Set the drawings length units to the same as the assemblys length units
					oDrawing.UnitsOfMeasure.LengthUnits = oDoc.UnitsOfMeasure.LengthUnits
				End If
				'Set a reference to the drawing sheet
				Dim oSheet As Sheet = oDrawing.ActiveSheet
				'Create the flatpattern view
				Dim oView As DrawingView = oSheet.DrawingViews.AddBaseView(smPartDoc, oTG.CreatePoint2d(oX, oY), 1 _
				, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, _
				"FlatPattern", , oBaseViewOptions)
				oView.Name = smPartDoc.DisplayName
				oView.ShowLabel = True
				'Set the position with our oX and oY
				oView.Position = oTG.CreatePoint2d(oView.Position.X + oView.Width / 2, oView.Position.Y)
				'Move oX to place the next view to the right of this one
				oX = oView.Left + oView.Width + 1
				'Remove the bend lines of the view
				RemoveBendLines(oView, oDef.FlatPattern)'You could comment out this line to keep bend lines
				oInfo = oInfo & If (i = 1, "", vbCrLf) & i & ". " & smPartDoc.PropertySets.Item("Design Tracking Properties"). _
				Item("Part Number").Value
				i += 1
				'Close the part
				smPartDoc.Close(True)
			End If
		Catch Ex As Exception
			MsgBox(Ex.Message)
		End Try
	Next
	If oDrawing IsNot Nothing
		'Create the save location string for the DXF
		Dim oDXFName As String = oPath & "\" & oAsmName & "_FlatPatterns.dxf"
		'Save the DXF
		oINI = "" 'Specify your INI file location here (eg C:\TEMP\DXF Export.ini)
		If oINI = "" Then
			MessageBox.Show("You need to specify an INI file location in the code - Look for oINI and set the path", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
		End If
		SaveDXF(oDrawing, oDXFName, oINI)
		'Create the save location string for the information txt
		Dim oInfoName As String = oPath & "\" & oAsmName & "_FlatPatterns.txt"
		'Create the txt
		CreateTXT(oInfo, oInfoName)
	End If
	'Close the drawing
	oDrawing.Close
	'return information about any unsaved parts
	If unsavedSmParts <> "" Then _
	MessageBox.Show(unsavedSmParts, "Some parts were not saved", _
	'Update the assembly (could be dirty if any flatpatterns were created)
	oDoc.Update
End Sub
Sub SaveDXF(oDrawing As DrawingDocument, oFileName As String, oIniFile As String)
	'Set a reference to the DFX translator
	Dim DXFAddIn As TranslatorAddIn
	DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
	'Create translation context
	Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	'Create options for the translation
	Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	'Create a DataMedium object
	Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'Set the options (which .ini-file to use)
	If DXFAddIn.HasSaveCopyAsOptions(oDrawing, oContext, oOptions) Then
		oOptions.Value("Export_Acad_IniFile") = oIniFile
	End If
	'Set the filename property of the DataMedium object
	oDataMedium.FileName = oFileName
	Try
		'Try to save the DXF
		DXFAddIn.SaveCopyAs(oDrawing, oContext, oOptions, oDataMedium)
		MessageBox.Show("Dxf saved to: " & oFileName, "DXF SAVED", MessageBoxButtons.OK, MessageBoxIcon.Information)
	Catch
		MessageBox.Show("Couldn't save dxf!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
	End Try
End Sub
Sub RemoveBendLines(oView As DrawingView, oFlattPattern As FlatPattern)
	'Get all the bend edges from the FlatPattern
	Dim oBendEdgesUp As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge)
	Dim oBendEdgesDown As Edges = oFlattPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge)
	For Each oEdge As Edge In oBendEdgesUp
		'Get the curves representing these edges in the drawing view
		For Each oCurve As DrawingCurve In oView.DrawingCurves(oEdge)
			For Each oSegment As DrawingCurveSegment In oCurve.Segments
				'Set visibility to false
				oSegment.Visible = False
			Next
		Next
	Next
	For Each oEdge As Edge In oBendEdgesDown
			Next
		Next
	Next
End Sub
Sub CreateTXT(oText As String, oFileName As String)
	Dim oTxtWriter As System.IO.StreamWriter = System.IO.File.CreateText(oFileName)
	oTxtWriter.WriteLine(oText)
	oTxtWriter.Close()
End Sub
A.Acheson
@ali_akay welcome to the forum. Do you currently store thickness and qty within the iproperty? If not this will take a little work but is fairly easy when you know where to look within the API Help.
Steps needed.
1. Retrieve the values needed from the document(sheetmetalpart) being processed  in this case item quantity and thickness and check unit is what is expected.
2. Pass value to output sub routine as argument.
Step1.
You can get the qty from the BOM Row that is used to select the document is a valid sheetmetal part.
Syntax
BOMRow.ItemQuantity() As Long
'Display item count in logger.
Logger.Info(oRow.ItemQuantity)
Next you can get the  thickness from the
Syntax
SheetMetalComponentDefinition.Thickness() As Parameter
'Display thickness in logger.
Logger.Info(oDef.Thickness)
I will give you some time on step 1  to see if you can insert those into the rule in the correct position. Then have the logger open and see if values are what you expect. Hopefully this will help you identify the objects needed and where.
Regards
Alan
ali_akay
@A.Acheson thanks for your wellcome and help. i did it 😊
oView.Name = smPartDoc.DisplayName & " Thickness:" & oDef.Thickness.Value & " QTY:" & oRow.TotalQuantity
in the other hand when i test it, another problem noticed.
A.Acheson
Could you explain a little more with some images etc of what you mean by mirror not going to flat pattern?. The rule is working through the BOM rows and find parts with the same part number so shouldn't have any problem with mirrors.
Regards
Alan
