iLogic execute rule in part of assembly
sathish_rD64VU
sathish_rD64VU
When I execute an iLogic rule in my part, it takes a significant amount of time to complete. I have written rules for simple processes, yet they still take hours to execute. How can I reduce the execution time of these rules in Inventor? I have already raised a case with Autodesk 23956036, but they have been unable to provide a solution. I kindly ask for your assistance in resolving this issue, as it is affecting our commitments to our customers.
ryan.rittenhouse
Lots of things can affect how long your ilogic takes to run. Some processes are very computationally expensive and some methods of doing things are less efficient than others. Can you post your code so we can see what it's doind?
If this solved your problem, or answered your question, please click Accept Solution.
sathish_rD64VU
Hi Ryan, I have shared a part of code here, Please check it and give suggestions:
Dim Result As DialogResult = MessageBox.Show("Need to update the Master model as per model input excel", "Updation request", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
'Result = MessageBox.Show("Need to update the Master model as per model input excel", _
'"Updation request", _
'MessageBoxButtons.YesNo, _
'MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If Result = DialogResult.Yes Then
' Define the path to the Excel file
Dim excelFilePath As String
excelFilePath = "Z:\DESIGN\O T H E R S\JEDIT CALVIN JEHOASH\TCS\Ball strainer Model Inputs.xlsm"
' Get the Excel application object
Dim excelApp As Object
excelApp = CreateObject("Excel.Application")
' Open the Excel workbook and sheet
Dim excelWorkbook As Object
Dim excelSheet As Object
excelWorkbook = excelApp.Workbooks.Open(excelFilePath)
excelSheet = excelWorkbook.Sheets("Modelinputs") ' Your specific sheet name
' Get values from Excel and update Inventor parameters
'Parameter("FLANGE_STANDARD") = excelSheet.Range("C2").Value
'Parameter("RAISED_FACE_FLAT_FACE") = excelSheet.Range("C3").Value
'Parameter("AWWA_DN") = excelSheet.Range("C4").Value
'Parameter("AWWA_CLASS") = excelSheet.Range("C5").Value
'Parameter("ASME_DN") = excelSheet.Range("C6").Value
'Parameter("SHELL_LENGTH") = excelSheet.Range("C8").Value
'Parameter("SHELL_THK") = excelSheet.Range("C9").Value
'Parameter("SCREEN_ANG") = excelSheet.Range("C10").Value
'-------------------------EXCEL INPUTS-----------------------------------------------------------------------------------------------------------------------
'COMMON DATA
Parameter("MASTER Sketch:1", "SCR_ELI_LEN") = excelSheet.Range("F19").Value 'SCREEN ELIPSE LENGTH
Parameter("MASTER Sketch:1", "DN") = excelSheet.Range("C18").Value 'DN SIZE OF THE SHELL WHICH IS BALL STRAINER'S ID
Parameter("MASTER Sketch:1", "FLANGE_STANDARD") = excelSheet.Range("C7").Value 'MAIN FLANGE STANDARD
Parameter("MASTER Sketch:1", "RUBBER_LINING") = excelSheet.Range("H7").Value 'RUBBER LINING THICKNESS
Parameter("MASTER Sketch:1", "SHELL_LENGTH") = excelSheet.Range("C19").Value ' OVERALL LENGTH OF THE SHELL
Parameter("MASTER Sketch:1", "SHELL_THK") = excelSheet.Range("C9").Value 'THICKNESS OF THE SHELL
'--------------------------SPECIAL LINKING------------------------------------------------------------------------------------------------------------------------------
Parameter("MASTER Sketch:1", "SCR_SUP_PIPE_DIS1") = excelSheet.Range("L31").Value
Parameter("MASTER Sketch:1", "SCR_SUP_PIPE_DIS2") = excelSheet.Range("L32").Value
Parameter("MASTER Sketch:1", "SCR_SUP_PIPE_DIS3") = excelSheet.Range("L33").Value
Parameter("MASTER Sketch:1", "SCR_SHOE_PLATE_LEN") = excelSheet.Range("L34").Value
Parameter("MASTER Sketch:1", "SCR_GUS_STIF_N") = excelSheet.Range("L35").Value
Parameter("MASTER Sketch:1", "BALL_EXT_FIX_27") = excelSheet.Range("I21").Value'CHANGED LOCATION-"ALSO IN BOTTOM"
Parameter("MASTER Sketch:1", "BALL_EXT_FIX_49") = excelSheet.Range("L36").Value
Parameter("MASTER Sketch:1", "BALL_EXT_FIX_9") = excelSheet.Range("L37").Value
Parameter("MASTER Sketch:1", "SCREEN_LEN_1") = excelSheet.Range("L38").Value
Parameter("MASTER Sketch:1", "SCR_STIFFNER_GAP1") = excelSheet.Range("L39").Value
'Parameter("MASTER Sketch:1", "SCR_STIFFNER_GAP3") = excelSheet.Range("Bxx").Value
'Parameter("MASTER Sketch:1", "NAME") = excelSheet.Range("Bxx").Value
Parameter("MASTER Sketch:1", "SCR_STIFFNER_GAP4") = excelSheet.Range("L42").Value
Parameter("MASTER Sketch:1", "SCR_STIF_LEN1") = excelSheet.Range("L45").Value
Parameter("MASTER Sketch:1", "SCR_H_STIFF_NP1") = excelSheet.Range("L46").Value
Parameter("MASTER Sketch:1", "SCR_H_STIFF_NP2") = excelSheet.Range("L47").Value
Parameter("MASTER Sketch:1", "SCR_SPL_STIFF_NP") = excelSheet.Range("L48").Value
Parameter("MASTER Sketch:1", "BACKWASH_ANG") = excelSheet.Range("L49").Value
Parameter("MASTER Sketch:1", "SCR_FIX_24") = excelSheet.Range("L50").Value
Parameter("MASTER Sketch:1", "SCR_SUP_PIPE_MIN_DIS2") = excelSheet.Range("L51").Value
'Parameter("MASTER Sketch:1", "SCR_SUP_PIPE_MIN_DIS1") = excelSheet.Range("Bxx").Value
Parameter("MASTER Sketch:1", "SCR_RIB_WIDTH") = excelSheet.Range("L53").Value
Parameter("MASTER Sketch:1", "SHAFT_DIA") = excelSheet.Range("L54").Value
Parameter("MASTER Sketch:1", "SCR_RIB_GAP1") = excelSheet.Range("L19").Value'CHANGED LOCATION
Parameter("MASTER Sketch:1", "SCR_RIB_GAP2") = excelSheet.Range("L20").Value'CHANGED LOCATION
Parameter("MASTER Sketch:1", "SCR_SUP_DIS") = excelSheet.Range("L55").Value
Parameter("MASTER Sketch:1", "SCR_FIX_7") = excelSheet.Range("L56").Value
SCREEN_ANG = excelSheet.Range("C21").Value
BACKWASH_ANG = 360 - excelSheet.Range("L49").Value
'main flange nozzle
If Parameter("MASTER Sketch:1", "FLANGE_STANDARD") = "Awwa-Class B" Then
Parameter("MASTER Sketch:1", "AWWA_MF_OD") = excelSheet.Range("C40").Value
Parameter("MASTER Sketch:1", "AWWA_MF_N_H") = excelSheet.Range("C41").Value
Parameter("MASTER Sketch:1", "AWWA_MF_PCD") = excelSheet.Range("C42").Value
Parameter("MASTER Sketch:1", "AWWA_MF_H_DIA") = excelSheet.Range("C43").Value
Parameter("MASTER Sketch:1", "AWWA_MF_THK") = excelSheet.Range("C44").Value
ElseIf Parameter("MASTER Sketch:1", "FLANGE_STANDARD") = "Awwa-Class D" Then
Parameter("MASTER Sketch:1", "AWWA_MF_THK") = excelSheet.Range("C45").Value
ElseIf Parameter("MASTER Sketch:1", "FLANGE_STANDARD") = "ASME" Then
Parameter("MASTER Sketch:1", "ASME_MF_OD") = excelSheet.Range("C48").Value
Parameter("MASTER Sketch:1", "ASME_MF_THK") = excelSheet.Range("C49").Value
Parameter("MASTER Sketch:1", "ASME_MF_M_THK") = excelSheet.Range("C50").Value
Parameter("MASTER Sketch:1", "ASME_MF_HUB_DIA") = excelSheet.Range("C51").Value
Parameter("MASTER Sketch:1", "ASME_MF_RF_DIA") = excelSheet.Range("C52").Value
Parameter("MASTER Sketch:1", "ASME_MF_R") = excelSheet.Range("C53").Value
Parameter("MASTER Sketch:1", "ASME_MF_N_H") = excelSheet.Range("C54").Value
Parameter("MASTER Sketch:1", "ASME_MF_PCD") = excelSheet.Range("C55").Value
Parameter("MASTER Sketch:1", "ASME_MF_H_DIA") = excelSheet.Range("C56").Value
'N1 - Nozzle
Parameter("MASTER Sketch:1", "N1_XAXIS") = excelSheet.Range("B25").Value
Parameter("MASTER Sketch:1", "N1_YAXIS") = excelSheet.Range("B26").Value
Parameter("MASTER Sketch:1", "N1_DIS") = excelSheet.Range("B27").Value
Parameter("MASTER Sketch:1", "N1_PIPE_OD") = excelSheet.Range("B28").Value
Parameter("MASTER Sketch:1", "N1_PIPE_THK") = excelSheet.Range("B29").Value
Parameter("MASTER Sketch:1", "N1_FLG_OD") = excelSheet.Range("B30").Value
Parameter("MASTER Sketch:1", "N1_FLG_PCD") = excelSheet.Range("B31").Value
Parameter("MASTER Sketch:1", "N1_FLG_H_DIA") = excelSheet.Range("B32").Value
Parameter("MASTER Sketch:1", "N1_FLG_NH") = excelSheet.Range("B33").Value
Parameter("MASTER Sketch:1", "N1_FLG_ID") = excelSheet.Range("B34").Value
Parameter("MASTER Sketch:1", "N1_FLG_THK") = excelSheet.Range("B35").Value
jwingateRJECD
Do you have the excel reference/interop at the header of your rule?
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports Microsoft.Office.Interop
Imports Microsoft.Office.Interop.Excel
sathish_rD64VU
Hi Ryan,  We didn't add Excel reference at the header of the rule. Autodesk Team replied to our case and  they suggest that "commenting out the calls to Constraints.AddUcsToUcs() improves the performance of the rules", This gives good results.
