Changing custom properties output from inches to feet & inches
spanky
spanky
I'm trying to get my iLogic I've been using to output the Length custom property to ft-in. Right now it sets everything in inches rounded to the 1/16".
Any ideas? Any help would be GREATLY appreciated.
Thanks.
	    iLogicVb.RunRule("TOGGLEWORKFEATURES")
		InventorVb.DocumentUpdate()
		SPECAdder = 0
		Smallest = Measure.ExtentsLength
		Middle = 0
		Largest = 0
		If Measure.ExtentsWidth > Measure.ExtentsLength Then
			Middle = Measure.ExtentsWidth
		Else
			Smallest = Measure.ExtentsWidth
			Middle = Measure.ExtentsLength
		If Measure.ExtentsHeight > Middle Then
			Largest = Measure.ExtentsHeight
		Else
			If Measure.ExtentsHeight > Smallest Then
				Largest = Middle
				Middle = Measure.ExtentsHeight
			Else
				Largest = Middle
				Middle = Smallest
				Smallest = Measure.ExtentsHeight
		Largest = Largest + SPECAdder
		'iProperties.Value("Project", "Stock Number") = Round(Largest, 1) & "x" & Round(Middle ,1) & "x" & Round(Smallest , 1) & " "
		iProperties.Value("Custom", "LENGTH") = RoundToFraction(Largest, 1/16, RoundingMethod.RoundUp)
		iProperties.Value("Custom", "WIDTH") = RoundToFraction(Middle, 1/16, RoundingMethod.RoundUp)
		iProperties.Value("Custom", "HEIGHT") = RoundToFraction(Smallest, 1/16, RoundingMethod.RoundUp)
		iProperties.Value("Custom", "SECTION DIMS") = CStr(RoundToFraction(Smallest, 1 / 16, RoundingMethod.RoundUp)) + " X " + CStr(RoundToFraction(Middle, 1 / 16, RoundingMethod.RoundUp))
		'iProperties.Value("Custom", "LENGTHMM") = iProperties.Value("Custom", "LENGTH") * 25.4
		'iProperties.Value("Custom", "WIDTHMM") = iProperties.Value("Custom", "WIDTH") * 25.4
		'iProperties.Value("Custom", "HEIGHTMM") = iProperties.Value("Custom", "HEIGHT") * 25.4
This is the TOGGLEWORKFEATURES iLogic
For Each oWorkPlane In ThisDoc.Document.ComponentDefinition.WorkPlanes
	oWorkPlane.Visible = False
Next
For Each oWorkAxis In ThisDoc.Document.ComponentDefinition.WorkAxes
	oWorkAxis.Visible = False
Next
For Each oWorkPoint In ThisDoc.Document.ComponentDefinition.WorkPoints
	oWorkPoint.Visible = False
Next
MercuryOptimizationSolutions
Hey @spanky, just want to make sure I understand what you are trying to do, you have a custom "LENGTH" iproperty that is currently displaying as inches and you want it in ft-in?
I know you can do this easily in visual studio so I suspect it should be the same in iLogic, are you able to provide a sample part?
P. Andrew White, P.Eng
Consultant Manufacturing Engineer | Architect of Optimization | Autodesk Developer
spanky
Here is a sample part with the rules active.
Ah, I see the issue. The custom property is created as a number which is effectively "unitless". Not sure if this works for your purposes but I added another custom property as a "text" type and used this equation in the iLogic:
		iProperties.Value("Custom", "LENGTH2") = Round(Largest/12,0) & "ft-" & Round(Largest-Round(Largest/12,0)*12) & "in"
So the value in "LENGTH2" in your example would display "10ft-0in" but note this is text so if you have this value being used in an external system, it may not recognize it as a measurement.
Inventor itself will recognize this measurement as the parameters are calculated. So even though the document units are set to inches, Inventor can solve "10ft-0in" to mean a value of 120".
Hope this helps,
Andrew
spanky
