Ilogic Excel Look up
AMN3161
AMN3161
I am looking a code to look at a excel table and find a value like a tag, then pull the information next to that tag in the adjustment cell. I also working to learn ilogic so some explanation on what the code is doing would be appreciated. So if the column has PSV-101 in A2 i want the information in A3 to get pulled into a preset iproperty.
thank you in advance
Hi @AMN3161,
To read a value in excel file and assign it to parameters, you can start the code below and adjust it according to your needs.
ExcelFile = "C:\folder\ExcelfileName" & iProperties.Value("Custom", "iLogicRulename") & ".xlsx"
d0 = GoExcel.CellValue(ExcelFile, "Sheet1", "A1")
d1 = GoExcel.CellValue("A2")
d2 = GoExcel.CellValue("A3")
AMN3161
This is great thank you so much!
AMN3161
so i was a little premature with my thanks yous.
I should of explained this a little better but i want it to search for a value in a row, the pull the adjacent value in the column next to that value.
dleesuk
Hi Adam,
I'm not sure this will help, but I created an iLogic routine some time ago which searched an Excel spreadsheet to populate the parameters to build an hydraulic cylinder.  The parameters were used to modify 2 existing parts to the sizes required and also drove parameters in the assembly.
The data I used is from the APH Cylinders data sheet. The data runs in columns as opposed to rows as you ask.
I have attached a snippet of my data set for you to compare with the code.
Hopefully, by going through the code and comparing it to the data the code will make some sense and allow you to build your own routine.
Dim ExcelFile = "THIS WOULD BE THE LOCATION OF YOUR DATA SET\*****.xlsx"
i = GoExcel.FindRow(ExcelFile, "Sheet1", "Series", "=", Parameter("CylinderSeries"))
'Gather APH CYLINDER parameters from Excel spreadsheet and assign them to local variables
Rod  = GoExcel.CurrentRowValue("Rod")
D3  = GoExcel.CurrentRowValue("D3")
D4  = GoExcel.CurrentRowValue("D4")
D6  = GoExcel.CurrentRowValue("D6")
D7  = GoExcel.CurrentRowValue("D7")
L1  = GoExcel.CurrentRowValue("L1")
L2  = GoExcel.CurrentRowValue("L2")
L3  = GoExcel.CurrentRowValue("L3")
L4  = GoExcel.CurrentRowValue("L4")
L5  = GoExcel.CurrentRowValue("L5")
L6  = GoExcel.CurrentRowValue("L6")
L7  = GoExcel.CurrentRowValue("L7")
L8  = GoExcel.CurrentRowValue("L8")
L9  = GoExcel.CurrentRowValue("L9")
L10 = GoExcel.CurrentRowValue("L10")
L11 = GoExcel.CurrentRowValue("L11")
L12 = GoExcel.CurrentRowValue("L12")
L13 = GoExcel.CurrentRowValue("L13")
L14 = GoExcel.CurrentRowValue("L14")
Stroke = Parameter("Stroke") 'Local parameter
' Cylinder Body Details
Parameter("Body.ipt", "CylBodyDia") 		= D3
Parameter("Body.ipt", "EyeWidth") 			= L11
Parameter("Body.ipt", "EyeThickness") 		= L9
Parameter("Body.ipt", "SwivelEyePos") 		= L12
Parameter("Body.ipt", "SwivelEyeDiameter") 	= D7
Parameter("Body.ipt", "OverBall") 			= L10
Parameter("Body.ipt", "SwivelHoleDia")	 	= D4
Parameter("Body.ipt", "PortPos1") 			= L7
Parameter("Body.ipt", "PortPitch") 			= L3
Parameter("Body.ipt", "PortHeight") 		= L8
Parameter("Body.ipt", "CylStroke") 			= Stroke
Parameter("Body.ipt", "BodyLength") = ((L14 + Stroke) - L6 - (2 * L12))
If Parameter("CylinderSeries") < 48
	Feature.IsActive("Body.ipt", "Port Pattern") = False
Else
	Feature.IsActive("Body.ipt", "Port Pattern") = True
Parameter("Body.ipt", "BodyColour") = Parameter("CylColour")
' Cylinder Rod Details
Parameter("Rod.ipt", "RodDia") = Rod
Parameter("Rod.ipt", "RodLength") = Stroke + 50
Parameter("Rod.ipt", "EyeWidth") = L11
Parameter("Rod.ipt", "EyeThickness") = L9
Parameter("Rod.ipt", "SwivelEyePos") = L12
Parameter("Rod.ipt", "SwivelEyeDiameter") = D7
Parameter("Rod.ipt", "OverBall") = L10
Parameter("Rod.ipt", "SwivelHoleDia") = D4
Parameter("MinCentre") = Stroke + L14
Parameter("MaxCentre") = (Stroke*2) + L14
Parameter("Rod.ipt", "RodColour") = Parameter("CylColour")
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
GoExcel.Close
Regards
Darren
AMN3161
I just test this its exactly what I need, thank you!!!!
dleesuk
Hi Adam,
Could you please accept this as a solution.
Thank you
Regards
Darren
